Domestic Swaps Chevrolet, Ford, ect
The Swap is On! Toyota,Mercruiser and Chevy?
Old Feb 4, 2009 | 05:28 PM
  #101
texcat101's Avatar
The new "chevy swap" radiator from extremeradiator.com
Really not any different than the stock 3 core copper/brass except they swapped the inlet and outlet locations side to side to work better for the 4.3
They should have used a 1 1/2" lower nipple to make it work better... try finding a 1 3/4"
by 1 3/8" flex hose 15" long. I will have to use reducer bushings and a dab of rtv.
Old Feb 4, 2009 | 06:06 PM
  #102
Hayes's Avatar
looking good!
Old Feb 5, 2009 | 05:37 PM
  #103
texcat101's Avatar
update
I thought I would post the Gates part #'s for the radiator hoses, the short one is the lower. The rubber adapter bushings are for 1 1/4" but they easily stretched over the 1 3/8" radiator nipples, it didn't make for as tight a fit as I would like but with a good clamp I think it will work okay. I double clamped the lower.
Old Feb 6, 2009 | 05:45 PM
  #104
texcat101's Avatar
update, taking shape
got the edis plug wires, and air filter installed this afternoon. Very close now, this engine does look strange in the 4runner, but I like it.
Old Feb 6, 2009 | 06:09 PM
  #105
olharleyman's Avatar
Wow I like how empty it looks in there lots of room to work unlike the 3.0. I am thinking about doing the same to my 93 but not sure if my 4 cylinder 5 speed will hold up to it or if I need a v6 5 speed either way I LIKE IT looks super clean.
Old Feb 6, 2009 | 06:44 PM
  #106
texcat101's Avatar
The 4.3 fits well I removed most of the harness, filter box, pwr steering reservoir. Lots of guys doing v8's- not for me, I like having the room.
Old Feb 8, 2009 | 04:26 PM
  #107
texcat101's Avatar
weekend update
I finished wiring the MSII relay box, I needed an Isolator for all of the extra terminals and circuits [ edis, starter relay, stereo amp...] so I installed this battery isolator switch to serve both purposes...
..finished the tranny cooler plumbing
installed the adjustable vacuum switch for lockup control on the 700r4, this will allow more control over the lock up and kickdown timing.
Old Feb 10, 2009 | 05:04 PM
  #108
texcat101's Avatar
exhaust installation
I had my exhaust installed today by a local shop, 2.25" from the header on each side to 2.5" at the Y, on back thru a generic flomax and out on the drivers side.
The big question on this job was where to crossover, we chose to do it back of the t'case instead of the gap between the tranny pan and converter cover
The tailpipe exits a little too low [something I can fix] but overall its a good job- we shall see how it performs and sounds.
Old Feb 10, 2009 | 07:26 PM
  #109
Hayes's Avatar
how close are you to firing this thing up?
Old Feb 14, 2009 | 01:18 PM
  #110
texcat101's Avatar
I had to learn some of the megatune basics and configure the program to burn to the ecm....
I fired it up today and it sounds mean!!
I have to do more tuning and that will be much easier to do tuesday when my buddy with the MS Zuk comes over... but It's alive!!
Old Feb 14, 2009 | 02:07 PM
  #111
texcat101's Avatar
It's Alive video!
Old Feb 14, 2009 | 02:30 PM
  #112
Adam F's Avatar
Nice feeling to finally get it running huh? I like the exhaust work!
Where did you get that shorty intake boot? What diameter is the opening on your throttle body?
Old Feb 14, 2009 | 04:30 PM
  #113
Hayes's Avatar
sounds mean. Nice work.
Old Feb 14, 2009 | 10:41 PM
  #114
texcat101's Avatar
The intake " Hat " came off a late model vortec in a junk yard, I found it laying in the grass next to several new chevys, the spectre filter from autozone had 3" 3.5" and 4" adapters that came with it, the 3.5" fit nicely.
The throttle body opening on the mercruiser intake is the same size as the stock GM 4.3 but does not have the restricter on the back of the plate.. right at 3"
Old Feb 15, 2009 | 05:18 AM
  #115
texcat101's Avatar
Here's the screen from the first run at warmup, needs some tuning, but cool!
Old Feb 15, 2009 | 03:06 PM
  #116
son of texcat's Avatar
Dad its seriously a beast now, and yes i made a account, cause it ticked me off that i couldnt message u on this thread. U goin 2 ft phantom 2 test it out? U still got some wiring left right? Oh btw my tranny in the mazda is startin 2 slip a little bit I THINK. So if u could check it out wit me nxt time u come down itd b much appreciated! TTYL
Old Feb 15, 2009 | 06:24 PM
  #117
texcat101's Avatar
You never know who will drop by to say hello - it's the P.O.
I got the wiring 90% finished today, maybe 30 minutes left . I have to rebuild the drivelines before I do the real test runs.
Old Feb 25, 2009 | 06:17 PM
  #118
texcat101's Avatar
With the 700r4 swap there is a clearance problem with the tranny pan, its necessary to change to a smaller diameter drive shaft and it must be lengthened as well. I also picked up an old dbl cardon from the wrecking yard to convert the rear driveshaft to a CV type setup.
I installed the old stock 4.30 gears in the rear diff in preparation for a good testdrive, should give me 2100 rpm at 70mph. If I like the results I will install the front set.
Old Mar 3, 2009 | 06:15 PM
  #119
texcat101's Avatar
I got the driveshafts back from our local shop, He installed the double cardon from the wrecking yard that I rebuilt and shortened the shaft -44"
The front shaft had to be lengthened and a smaller diameter main tube was installed to give clearance for the 700r4 tranny pan.
Road test tomorrow!!
Old Mar 3, 2009 | 07:51 PM
  #120
idayota's Avatar
wow! congrats man. looks great. i really like the looks of how the engine bay came out. very clean, especially the fan shroud. can't wait to see some road/trail pics.
