Domestic Swaps Chevrolet, Ford, ect
starting a swap 2004 5.3L to a 85 yota
Old 07-23-2009, 12:05 AM
brandonakio808's Avatar
please tell me where to start...what kind of adapter to bolt up to my 85 trans to a 5.3L v8. i have the whole donor truck so i can use whatever off of it. has anyone done it ? i heard you have to need to move everything back 6 inches. im chopping the donor up now and saving the whole wiring from the donor. what kind of fuel pump / bell housing/flywheel(b/c auto donor) /clutch/slave/.................please help....any kind of pointers would be nice...im doing this cause i blew up 2 motors and warp 1 head, losts of elec probs and just tired of of working on 22's and then this donor came along. i just need more power plus i tow alot..please dont hate me..hehe
Old 09-10-2009, 07:07 PM
StangBanger's Avatar
Im looking to do the same swap but havent found any good info. You get started yet?
Old 09-10-2009, 07:13 PM
Adam F's Avatar
www.advanceadapters.com
Old 09-10-2009, 07:23 PM
Thats a start..
Old 02-12-2010, 05:15 PM
z71bg1690's Avatar
i am doin the same swap out of a 1999 silverado , i am doing no body life and all suspention i think i am goin with probibly 6 inches and i am also doing a sas i got the motor test fit and it has good clearence i am using the 4l60-e tranny and my toyota transfer case i am going to get the adapter from northwestoffroad.com they are the only ones i have found that have it , i chose that route because it cheaper than buying bellhousing ,clutch ,flywheel ad all that . I aint moved nothing i am running my rear leaf spring on the front and chevy leafs in the back . let me know how yours is goin
Old 02-12-2010, 07:53 PM
85 chevota's Avatar
Man, the wiring part of that might be a pain. All the emission garbage has really complicated things on the newer vehicles. If I remember right the fuel pump and sending unit are all one unit and it has sensors that check for tank pressurizing ect.... Do you know if it has an egr vavle? I know the 04 4.3 engine w/ X engine code doesn't but, it relies on the 2 cats and 3 o2 sensors to meet emissions but having an advanced warm. Even the wiring for the dash guages is complicated going through the bcm. I'm curious as to how it will turn out and if you can get a harness and ecu for the swap. If it does work the 5.3 is a great engine for both power and economy! A Toy with one of those would haul a$$!
Old 02-13-2010, 04:14 PM
z71bg1690's Avatar
i am getting a friend that works at the chevy dealership to give me a gm wiring diagram with all the stuff i dont need to make it run crossed out and he is good at that stuff so i think i got the wiring covered i know i am going to have to keep my oxygen sensor (all 4) but i will know more when i get it
Old 02-13-2010, 04:30 PM
Sweet..Sharing is careing..
Old 02-14-2010, 06:24 AM
85 chevota's Avatar
I did a little research after the last post I made and found a couple places sell stand alone ecu's and harnesses for hot rod type applications. I think it was coppco.com even sold extras like vss and egr block offs. Also found out you can buy a complete engine, harness, and ecu ready to drop in from gm performance parts so looks like there's lots of stuff out there for 5.3 swap!
Old 03-09-2010, 02:28 PM
whitedevil666's Avatar
I'm surprised more people aren't doing this. Look in this forum for metric ass-tons on info on this type engine: http://www.ls1tech.com/forums/conver...de-1500-a.html
That particular thread I linked is full of great stuff. That guys has done a lot of swaps. I have been considering a 5.3 for my 94 'runner. The 3vze is pretty long in the tooth, and I don't find it all that easy to work on. If you could get the accessory drive from a fwd application like a grand prix gxp or impala ss, it would probly leave room for a puller fan.
Old 03-19-2010, 07:24 PM
ridgerunner4x4's Avatar
Mega Squirt can build any computer that you want. Also tpichips.com can do the same. Good Luck! Im putting a 383 stroker with a TPI from a Corvette and using the Mega Squirt.
Old 03-23-2010, 08:03 PM
VEGASROBBI's Avatar
2007 All aluminum 5.3 H.O. LH6 with AFM(4cyl mode).
Old 03-23-2010, 08:15 PM
RMA
RMA's Avatar
Attachment 80451
Attachment 80452
Dude !! Wheres the right up on this one..
Nice truck ..
Old 03-25-2010, 05:57 PM
VEGASROBBI's Avatar
Nice truck ..
Some old pics.
http://s418.photobucket.com/albums/pp265/VEGASROBBI/
rbravo1
06-29-2015 01:34 PM
serenity03k64
06-27-2015 07:59 AM
ibayne
06-26-2015 06:30 AM
duckhead
3.4 Swaps
7
06-18-2015 06:54 AM
2wdtundra
06-17-2015 01:41 AM
Quick Reply: starting a swap 2004 5.3L to a 85 yota
