Domestic Swaps Chevrolet, Ford, ect
302 Swap
Old Jun 30, 2007 | 06:13 PM
LittleSilver113's Avatar
302 Swap
So Ive got a 302 HO out of an 84 stang and I think it needs to find a home in yota. I was wondering what would be a good manual trans to stick behind it. I did some research on the t5 from that same car and it had the same ratios as the yota except for 5th gear. I also heard that the w56 will hold up for a while as long as its driven sensibly but who does that. Anyways I need some input I want this thing in within a couple weeks or so. NV4500, T18, NP435?????? Not sure about losing a gear though for freeway use.
Old Jun 30, 2007 | 06:19 PM
Jay351's Avatar
The stock 5sp from a 89-95 v6 (r150?) Is plenty strong.
pretty much all the v6 gear is overbuilt for that engine.
Old Jun 30, 2007 | 06:28 PM
Do you know if the R150 will bolt up to the transfer case from the 22re pickup? Or are they different cases?
Old Jun 30, 2007 | 06:30 PM
Jay351's Avatar
Im pretty sure you can get an adapter, but you might just want to track down a tranny+ t-case combo.
Old Jun 30, 2007 | 06:31 PM
Good Idea I think thats what I will do. I would like to keep the truck as much toyota as possible so thats good to hear.
Old Jun 30, 2007 | 07:48 PM
s_wall98's Avatar
Do some searching, I've seen this done before.
Old Jun 30, 2007 | 07:53 PM
deathrunner's Avatar
check www.downeyoff-road.com
They have alot of info about swapping, at least in there print catalog.
Old Jun 30, 2007 | 08:42 PM
DudeBud's Avatar
if you want a toyota tranny go with a r151 and the t-case that goes with it less adapters to buy and you get 23 spline.
Old Dec 12, 2007 | 11:09 PM
rockdawg84's Avatar
We need an update.
Old Mar 17, 2011 | 06:31 PM
TG87runner's Avatar
Originally Posted by rockdawg84
We need an update.
Bringing this one back from the dead . I'm interested in this swap in my runner
Did this project ever get off the ground?
Old May 5, 2011 | 08:50 PM
eastoncatcher3's Avatar
yes im intersted too. i got a 302 in my ford and im about to buy a f250 and i want the 302 in my yota.
Old Jul 28, 2011 | 07:32 AM
884runner,78corolla's Avatar
nv4500
if you are planning on puting your truck through the ringgers i would highly reconmend throwing a nv 4500 at it, i work at a trans shop and have seen the yota trannys grenade with big tires and a heavy foot, my good freind has a 69 bronco with 35s and a 450hp 347 stroker in it and the nv 4500 he put in there loves every minuet of it.
cheers
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
exporunner
3.4 Swaps
Aug 3, 2015 06:10 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
Gevo
Jul 29, 2015 11:15 AM
GeoRoss
Jul 24, 2015 03:03 PM
