Diesel Swaps Diesel engines
My OM617 inside build page
Old Sep 14, 2012 | 05:47 AM
  #141
2003mikem's Avatar
i just piced up a ney toy.
a new to me welder to replace my hobart 135.
i now have a Millermatic 200.
nwer wip. new nozzles and tips and a new spool of .035.
and it has the14 pin for a spool gun.
all for the price of $325.00
Old Sep 14, 2012 | 05:50 AM
  #142
2003mikem's Avatar
new turbo diesel from the MB trunk
Old Oct 1, 2012 | 05:50 AM
  #143
2003mikem's Avatar
How a redneck strips a car
With a little help from my 85 4RUNNER
Old Oct 8, 2012 | 07:31 AM
  #144
2003mikem's Avatar
Originally Posted by 2003mikem
I got my Autometer mini warning lights.
One for oil pressure and one for coolant temp
Now I just have to rework the thermostat housing for 2 sending units
And drill and tape the oil filter housing cover.
I finally got around to drilling and tapping the Mercedes oil filter housing cover to add an auto meter warning light. Here is how it is done at least for me.
Make the spot to drill
Drill pilot hole
Drill correct size hole for the 1/8 27 NPT tap
Start taping
Use NPT gauge to make sure I done over tap since the NPT is tapered.
Old Nov 29, 2012 | 05:05 AM
  #145
2003mikem's Avatar
I put some Bush Wacker fender flares on to cover the rust.
Old Dec 9, 2012 | 05:54 PM
  #146
2003mikem's Avatar
I just got done plowing with my 4Runner and it is a night and day from the 22re to the diesel.
Diesel is much better
Old Jan 3, 2013 | 04:43 AM
  #147
2003mikem's Avatar
Plowing for 6 hours 29.1 MPG
Old Jan 3, 2013 | 06:42 PM
  #148
Phessor's Avatar
Did you use a tach? How do you hook it up?
Old Jan 3, 2013 | 10:06 PM
  #149
PowerstrokeJoe's Avatar
Most have found the easiest way to run a tach is the adapter from Dakota Digital. It counts the teeth on the ring gear. There is one that has its own reluctor wheel as well.
Old Jan 4, 2013 | 05:38 AM
  #150
JayKray's Avatar
I used the Dakota digital adapter using a signal off of the alternator. I'm am having some issues getting it calibrated properly, but I really haven't given it too much time. It gives me a good idea of what is going on though.
Old Jan 26, 2013 | 05:57 AM
  #151
DirtyHarry460's Avatar
how much did it cost you to get your flywheel machined?
Old Jan 26, 2013 | 07:00 AM
  #152
2003mikem's Avatar
I think 95-100.00 kinda high but I did not want to take a chance
Old Jan 26, 2013 | 07:17 AM
  #153
Ok thanks. Did they fill the prior wholes or did you do that?
Old Jan 26, 2013 | 08:17 AM
  #154
2003mikem's Avatar
No the holes are oblonged.
Old Jan 26, 2013 | 10:19 AM
  #155
ok, one last question, what do you have to do for the fuel tank? Ive been checking threads and not finding clear info. Can you use the toyota fuel pump? fuel lines etc.
thanks
Old Jan 26, 2013 | 10:21 AM
  #156
Transplanter's Avatar
Remove the pump and replace with a straight tube and the rest of the lines are OK to use.
Old Jan 26, 2013 | 03:05 PM
  #157
2003mikem's Avatar
Yes transplant is. Correct
Old Feb 20, 2013 | 05:44 PM
  #158
DANIELS1985's Avatar
awesome swap.
i did a turbo diesel swap also, but i used a original 85 toyota motor.(i really like the merc motor but i was able to get the toy cheep) it was somewhat a plug and play , give or take a few wires. maybe someday ill run the merc, it would be nice if my truck could even do 75. lol
i see you have some lift in the truck, did you have to modify your plow mount at all?
Old Feb 20, 2013 | 06:11 PM
  #159
2003mikem's Avatar
Originally Posted by DANIELS1985
awesome swap.
I made the mount from scratch. I based it on the western one I found online
Old Mar 10, 2013 | 08:27 PM
  #160
wrenchtech's Avatar
You are fine where your at Mike, these engines can support just over 300hp on stock internals. Been runnin the bejesus out of mine for a year now at 21psi and if was gonna throw a rod it would be in my lap by now.
Internals good for 300hp. Anybody else know about this?
Also, What kind of power can you squeeze out of these engines without big $$$? I think something like 180hp, 240tq would be great in a 3rd gen p/u, or 2g 4runner.
