My OM617 inside build page
#122
Cut a slice In the metal collars from the stock hoses and remove the stock hoses, then you can replace the hose with 5/8 Lola hose and regular hose clamps. No need to go to hydraulic hoses and fittings as you will never see over 80 psi. Should cost about $40 for all of it.
#126
#127
Lola? Never herd of it before. I used hose and fittings from tractor supply worked out good. 2 - 36" 1/2 npt hydrolic hoses were $16 a piece. 2- 3/8 npt to 1/2 npt for the filter housing to hyd line were $5 a piece. 2- 90* brass fittings and a small brass pipe to off set the lower hose to clear the motor mount $8 at home depot. Then 2- 1/2" barbed to 1/2" female fittings for the Cooler side $10 . So I'm at $60 and the hose is rated at 3500 psi. I do see an average of 90 psi on a cold start up and the gauge maxes out at over 100 psi during the winter. Ive tried a few combos of hoses with barbed fittings and have had 3 big blow outs so far always at the hose clamp (side facing away from the barbed fitting. Also reg hose is just not durable enough to be in the engine bay with all the vibration.
#128
I got my Autometer mini warning lights.
One for oil pressure and one for coolant temp
Now I just have to rework the thermostat housing for 2 sending units
And drill and tape the oil filter housing cover.
#129
I will have to agree on the oil pressure as well. At start up I idle at 75-80 at running temp at idle 15-20 PSI at high way speeds 70-80 MPH I am between 70-95 PSI depending on how much my foot is in the pedal.
#131
I think the air might be a little too warn to do any good for the turbo. But I have thought about the oil cooler in a hood scoop. So looking forward to what you come up with. Subi scoop would be cool.
#133
Very busy weekend got a lot of things done and fixed.
Friday rebuilt the front solid axle due to leaking axle seals. Bought a marlin rebuild kit.
Saturday replaced drivers caliper and pads, clean and adjust the rear breaks
Sunday did the complete exhaust turbo back. all welded and heat wrapped front the turbo down about 34” to keep the heat soak from going into the oil pan.
It is to quite now all I hear is the tires going down the street.
#136
#138
oh cool... what land cruiser? if it's a 40 series or a 60 series i would really like to see the build up of that. after I get done with my current project I hope to build one of those two with a diesel. I'm really looking for a fj45 troopy but those are very hard to find here in the US.
