Diesel Swaps Diesel engines
88 sr5 4runner om617 swap
Old Nov 17, 2011 | 01:49 PM
riddarunner's Avatar
Originally Posted by pyrojoe22
I believe they say that (I may be wrong) because the over-engineered German motor mounts had shock absorbers integrated into them, which helped make them the luxury car they were back in the day. I bet they're still smooth, but I would also very much like to know how they perform. It'd be nice if you can use the stock Toy mounts (assuming that's what you are using). That's one of the very few items I haven't made yet for the swap, waiting to see where the engine sits in relation to the hood. Can you share with us what body lift you have, and if you left the tranny in its stock location?
Thank you
I am using the toyota motor mount bushings flat on the frame and the motor idles smooth and not much vibration.
Old Nov 17, 2011 | 01:53 PM
Originally Posted by dmarsh4x4
These are my mounts for 1988 4 runner
passenger side
driver side
They are just tacked up for now.
Your build is looking good
But i am defnitly going to copy your motor mounts....awesome!
Old Nov 17, 2011 | 04:22 PM
RBX's Avatar
RBX
I read on another forum that the merc mounts grafted to the yota frame rip apart during some wheeling in low. So if you, and I know you aren't, using those mounts you'd want to chain them down to keep them from separating. But that's what I read, I don't have any experience.
Old Nov 20, 2011 | 02:27 PM
nicholasm40's Avatar
Did you pull the over boost controller off the firewall? has a plastic tube going from back of intake to the ALDA on the injection pump?
Old Nov 22, 2011 | 08:24 AM
  #25
TigerToy88's Avatar
if you produced another pair of those mounts I would pay for them!!!!!
Old May 13, 2012 | 01:31 PM
  #26
22REFORME's Avatar
how are you guys routing your exhausts? i am curious....
Old May 13, 2012 | 02:22 PM
  #27
PowerstrokeJoe's Avatar
Mine is a little wacky but I am happy with it. It probably isn't the best for hard core off road things though.
Old May 13, 2012 | 04:40 PM
  #28
RBX's Avatar
RBX
Is there enough room to run the exhaust over the crossmember? I'm guessing no, is the e-brake in the way? I will need to to something similar when I swap to the 1kd-ftv.
Thanks
Old May 13, 2012 | 05:41 PM
  #29
22REFORME's Avatar
do you have a cat or a muffler on that?
Old May 14, 2012 | 06:31 AM
  #30
86bedlesstoy's Avatar
Good lookin'
Old May 21, 2012 | 02:25 PM
  #31
pyrojoe22's Avatar
Just posted up pics of mine on my thread
Old May 21, 2012 | 05:09 PM
  #32
No mine is all pipe and its really not loud at all in the cab with the windows up. Down on the other hand its pretty noisy. There isn't enough room to get the exhaust over the crossmember.
Old May 21, 2012 | 05:20 PM
  #33
22REFORME's Avatar
thanks for the info Joe.
the exhaust is on the top of my list of concerns, di u relocate any lines or hoses? how close the the starter is that pipe?
my adapter from 4x4labs arrived, yes i cheated.
spending my time with the important aspects of the swap.... doh
and finally, i did actually start working on getting the truck prepped..
Old May 21, 2012 | 08:06 PM
  #34
The pipe actually runs way over the starter. It goes down next to the firewall. I finally got a little free time so I'll grab some good pictures soon for you. Here you can sort of see how the dp is routed. Name:  IMG_1367.jpg
Honestly I stewed about the exhaust for the whole build. I took it to a local muffler shop here in town and told him sort of what I wanted. He really exceeded my expectations. and It only cost me $150. I will have to look more closely at the X-member in the morning as It might clear on your truck. I had to move mine back and the frame is a different width where I moved it.
I didn't re locate any hoses that I can think of. Its pretty much the way it came out of the car. Being that you have the adapter it should be a decently straight forward swap. The motor mounts are a PITA just because of where they are. Did you order a flywheel too?
Old May 22, 2012 | 03:01 AM
  #35
22REFORME's Avatar
wow 150 for an exhaust? where are you located here in ny theyd charge a few hundred to do that. i am going to be welding up the exhaust myself, i am thinking of getting fancy and using stainless with wiggens clamps and tigging the whole lot. in terms of the adapter i got everything 4x4labs offers, plate flywheel, and bushing. you have any plans for veggie oil? i removed the spare tire and that big empty space seems like a nice place for another fuel tank. speaking of fuel tanks, how did you prep yours and what kind of pump are you using?
also, any thoughts on intercooling? i know space is at a premium , i have been trying to dream up some plumbing.
Old May 22, 2012 | 07:15 PM
  #36
I live in central MO. He is a really great guy and known as the local go to guy for exhaust. I don't think I am going to run veggie. I am strongly considering WMO though as we have plenty around here with all the vehicles. 50/50 seems to be a pretty fair mix. As for the tank, I took out the stock fuel pump and replaced it with a rubber line.Its kind of a pain to do and if you live where rust is prevalent I would plan to replace that whole bracket as mine crumbled when I went to take it out. Its a dealer only part and is about $150. I am planning to intercool it later on. I will be using a water to air unit as I think I could put it where the battery is now and move the battery to the left fender well. That shouldn't be too hard to plumb. In my truck to would be impossible to run a air to air up front without bumper modifications. Good luck with your swap. I'm subscribed and if you run into anything that I can help with ask away!
Old May 28, 2012 | 01:46 PM
  #37
22REFORME's Avatar
baby got a bath... and still the grime remaines
Old May 28, 2012 | 06:04 PM
  #38
Riverdweller's Avatar
Was just wonderin why you decided on the 4by labs adapter and what you had to give for it? Can't wait to see it runnin.
Old May 28, 2012 | 07:37 PM
  #39
22REFORME's Avatar
well initially it was the only kit i was aware of, and although i think i could have made my own, finding the time to do it right was evading me. now that i have the adapter it has kind of jump started the project for me. i dont know much about the other kits that are now available, i do know that the rest of the fabrication(mounts, brackets and such) are far less critical in terms of failure than the adapter alignment. now that the motor has had a bath i dont mind wrenching on it as much.. haha
Old Jun 3, 2012 | 05:53 AM
  #40
22REFORME's Avatar
moving slowly... adapter mounted. not easy to get that bushing in the crank AT ALL.
