E-locker swap
E-locker swap
Hello this is Jack, I have a E locker out of a 1998 Tacoma superchargered sr5 ( the hole third member with 4:10 or 11's actualy). Wondering what size third member it is and what axle housing I need to locate? I have a 1980 toyota 4x4 and Iv been told that the third member wont fit so I figured ill just find a Tacoma axle oe anything along those lines. Any help or insight would be greatly appreciated.
It is an 8" third member. Your axle housing will work, but you will need the use of a metal grinder to make it fit. I suggest that you buy the paper gasket and use it as a template for where you need to make your cuts and you should be good to go.
Jun 1, 2021 01:51 PM
WTB[PacSoWest]: Looking for a electric locking differential motor/ actuator
AaronM
Jul 8, 2015 07:15 PM
