All Other Toyota Swaps I4, I6, Lexus V8
black89t's 7mgte swap
Old May 4, 2011 | 07:57 AM
black89t's Avatar
ITS ALIVE!!!!!
i got the truck going this past sunday been driving it every day since and its doing great! the 4.10's are soooooooooo much better. just partial throttle not getting into boost the truck scoots compared to the old gears. i did hit like 5psi in 2nd at low rpm and it started to sink me in the seat pretty good!!! havent rev'ed it that high yet because it has new rod bearing. gonna give it about 500 miles before a lay into it. also got a efan on it now too. the 7m in such a light rig is so much fun!!! the torque of that engine pushes that thing like nothing! pic to come.....
Old May 4, 2011 | 08:06 AM
dark_fairytales's Avatar
cool man, I can not wait to have the opportunity to swap to a 7m
Old May 4, 2011 | 08:33 AM
black89t's Avatar
Originally Posted by DIRT CLOD
DAAAAANNNG!!!! BLACK.... that truck is WELL WORTH a hundred bucks, just for the tires if they hold air.... you can easily make your money plus it looks like, even after you strip what you want....sub'd to this thread this looks awesome
yeah actually both trucks were a steal!!! i didn't end up selling anything off the square body truck. i did get a set of wheels/tires, body lift, and a 8" under perch rear! which is sorta rare i guess. i might use it but still considering all options. gonna see how the 7.5" rear holds up before i do anything though.
Old May 5, 2011 | 09:05 AM
black89t's Avatar
^for sure! i'll post a vid this weekend. i have a couple pics from my phone but they sorta suck. i'll get better ones up
this is the spare head i had laying around. its been milled, the exhaust studs helicoiled, and the valves adjusted to spec.
heres a pic of the bottom end i got from the picknpull. all i did to it was change the rod bearings, shimmed the oil pump, and called it good. its not burning any oil or smoking yet either! the felpro hg is chillin on the deck.
assembled long block.
right after we dropped it in.
3rd member with 4.10's from the front diff on a 87 4x4.
Old May 24, 2011 | 11:08 AM
  #25
ffryno13's Avatar
when i checked at the auto parts store they dont make the right 5m motor mount, are they the same? also can you post up some pics of how you mounted your intercooler and piping
Old May 25, 2011 | 08:20 AM
  #26
black89t's Avatar
yes the 5m motor mounts are the same but you dont need those. what you want is the motor mount BRACKETS. left and right are different with those. the exhaust side uses 3 bolts and the intake side uses 4 to the block. i got the set in the pic for like 50 shipped from the fs section on celicasupra.com. and you use the 5m brackets with the 22re motor mounts. ill get some pics up sometime soon.
Old May 26, 2011 | 09:16 AM
  #27
ffryno13's Avatar
sorry thats what i meant was the brackets. apparently they only make the intake side ahaha
Old Jun 12, 2011 | 04:14 PM
  #28
black89t's Avatar
i finally got a decent video to post and a current pic of the engine bay. also took the mud tires off and put the mini wheels back. its pretty fun. i have the boost at 14psi and all i can say is it scoots!!!
http://www.youtube.com/watch?v=2jrFgeQ7FkE
sanctfy
Sep 15, 2015 02:52 PM
exporunner
3.4 Swaps
Aug 3, 2015 06:10 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
Gevo
Jul 29, 2015 11:15 AM
GeoRoss
Jul 24, 2015 03:03 PM
