All Other Toyota Swaps I4, I6, Lexus V8
7mgte motor swap into 80
Old Apr 14, 2012 | 06:43 PM
  #41
INFINITY's Avatar
wiring is done.
now to finish up the other stuff and fire it up.
Old Apr 19, 2012 | 10:36 PM
  #42
INFINITY's Avatar
well i will post up some picts monday or so.
it runs, actually it is scary sounding. i have the exhaust downpipe made and it crossed over to the drivers side, the rad is in. now comes more little "just right" things to make it perfect.
Old Apr 27, 2012 | 08:19 PM
  #43
INFINITY's Avatar
i have the rad installed and oil cooler. water in the motor and everything hooked up. just need to fix some little stuff and do the exhaust and hood then should be good to go. this thing is scary fast. wow
Old Apr 28, 2012 | 05:51 AM
  #44
INFINITY's Avatar
also the oe supra oil and temp sending units work with the pickup gauge cluster (out of a 86 sr5)
Old Apr 28, 2012 | 06:35 AM
  #45
BMcEL's Avatar
Looking good so far! Haven't decided if I want to deal with the turbo yet, but my '80 is getting a 7m transplant sooner or later. Looking forward to videos.
No intercooler?
Old Apr 28, 2012 | 02:07 PM
  #46
INFINITY's Avatar
it is kind of a PITA with the turbo piping.
i ordered an inline water to air intercooler like a reverse radiator but in a tube. it will go ontop where the 3000 pipe is. so soon as i get it i will have an intercooler. the 1st gen trucks kind of have a short and smaller engine bay compared to the later trucks.
Old May 11, 2012 | 09:35 AM
  #47
INFINITY's Avatar
motor for now. i am going to move the oil cooler so the pusher fans can be mounted flush on the rad. installed a heat shield dividing the air intake from where the hot air from the rad will blow. drilled holes for better air inflow to the filter. going to get a couple of knock sensors this weekend to try to swap them out and see if they will fix the problem with code 52.
modified truck tach with the supra tach guts behind the gauge face so it reads correct. just moved some of the marks for the rpm range. since the truck tach died for some reason...
i am running a flowmaster single muffler and it sounds great better than i could have ever guessed.
also fixed some other stuff
Old May 11, 2012 | 10:14 AM
  #48
BMcEL's Avatar
Dude. Videos. Stat.
Old May 11, 2012 | 10:54 AM
  #49
Doitzel_Kaiser's Avatar
Nice! What did you do for motor mounts?
Old May 11, 2012 | 02:43 PM
  #50
streetlancer's Avatar
^I assume he used the 5mge/22r combo.
Dude that turbo looks awesome in there! It kinda makes me want to change my mind from an N/A swap. I'm in the same mindset as BMcEL; i don't know if i want to deal with a turbo engine. But....It's kinda too late to be having second thoughts now!! Lol.
Donor Supra!!
INFINITY>>>>> WE WANT VIDEO!!!!!!!!!!!!!!!! (X1000) <That's 16,000 exclamation marks right there! +1
Old May 11, 2012 | 03:32 PM
  #51
BMcEL's Avatar
Originally Posted by streetlancer
Donor Supra!!
Almost picked one up for $800 the other day. Just too much going on right now.
Old May 13, 2012 | 05:15 PM
  #52
INFINITY's Avatar
on page 1 i show what i used for the motor mounts (energy sus gm tranny mounts they are the same dia as the stock 22r mounts. but with the 20r the base of the mounts are actually narrower than for the 22r so i had to remove some material with a die grinder.
but yea bellhousing from a n/a 7m, the motor mount towers from a 5m and the energy sus mounts.
i picked up 2 knock sensors this weekend and a turbo heat shield. so tomorrow i will be putting them in and seeing if they work. i will post some videos then.
haha and i like the tosh.0 reference on the x 16k.
i have not gotten up to the highway yet but on dirt this thing is wild. i think this is the limits of power for safely controlling one of these old light weight trucks.
i will aso post some videos showing all of the problems i ran into and how to deal with them.
Old May 16, 2012 | 07:41 PM
  #53
Funny you mention that; that's exactly what the owner was asking. I talked him down a bit though.
That's great to hear; I can't wait to see those vids. That thing is gonna kick a$$!! Sleeper truck?
Old May 17, 2012 | 03:29 PM
  #54
INFINITY's Avatar
i am gonna vent the hood to help get rid of heat.
i replaced the knock sensors and it still hits 2k and it falls on its face.
so i am getting another ecu on tues so we will see what happens. im gonna retorque the head bolts and install the E-fans on tonight, and check the cam sensor.
Old May 18, 2012 | 04:47 PM
  #55
INFINITY's Avatar
i installed the fans and tightened the head bolts. here are some updated picts. also changed the oil (it was nasty from the engine breaking in). installed the front grill (but after i took the pict). cant wait to get the ecu on tues
Old May 21, 2012 | 08:27 PM
  #56
nothingbetter's Avatar
Hey! I didn't know you were on here too! I posted on the albertasupraforums site. Which transmission do you have dreams of in the near future? Your g series probally won't last too long. I'm on w56 #3 right now. Thats with average casual driving and occasional "I'm gonna beat you" pulls
Old May 23, 2012 | 07:03 PM
  #57
INFINITY's Avatar
well that is not a good sounding future for my gear box.
i swapped out the ecu for another and it is still throws the code 52 and falls flat on its face at 2-2800 rpm. above or below that it is fine.
the knock sensors are good and i rewired it once. but it even acts this if i unplug the sensors. so i dont know wtf??
Old May 23, 2012 | 07:10 PM
  #58
Are your knock sensors in the right holes? There are 3 holes in the block. the n/a version uses 1 sensor, the turbo uses 2. The n/a sensor goes in the middle hole, the turbo use the two outer holes and leaves the middle hole empty.
How did you re-wire the sensors? I followed a thread somewhere on the interporn and used shielded coaxial wire I picked up from a computer store. I grounded the shield in the cab near my ecu and my code went away.
Even with my code 52 it wouldn't fall on its face. That sounds more like an air/fuel ratio issue to me seeing as its only at 1 rpm range. does it make a difference if your real easy on the throttle?
Old May 24, 2012 | 12:38 PM
  #59
INFINITY's Avatar
as soon as i start it i can rev it up fine but about 30+ sec. after once it hits 2k it throws a code and stumbles until 2800 if it will get there without feathering it above. if i just crack the throttle it still stumbles just not as bad and the code comes on.
here is what it does.
http://www.youtube.com/watch?v=GjEox...ature=youtu.be
Old May 24, 2012 | 12:41 PM
  #60
INFINITY's Avatar
the exhaust leak if from the hole from my egt probe. i had to send it back due to it was a faulty sensor.
