All Other Toyota Swaps I4, I6, Lexus V8
1UZFE swap into 2nd Gen 4Runner
Old Mar 6, 2006 | 07:12 AM
  #401
PAhydrohead's Avatar
Mike,
Are you keeping your stock steering setup? I bent the shaft of my steering box in the recent accident and a new Toyota box is $$$$$$$$$$$$$$$$$$$ Insurance Co. wants to use a NAPA steering box and other misc. steering components so I don't have to total the truck.
Old Mar 6, 2006 | 09:12 AM
  #402
Cebby's Avatar
Damn, you must have really hit hard. I'll be reusing the stock steering - even when the SAS happens, you need to use the IFS box.
Old Mar 20, 2006 | 08:33 AM
  #403
mt_goat's Avatar
Originally Posted by Cebby
I just did the pan and cooler lines. I guarantee there is still plenty in there (in the tcase and torque converter. After I had the crossmember out and the driveshafts removed, I stuck a floorjack under the tcase end and tipped it up and got alot more out. Now that it's completely out, I can tip it up and empty it with my hoist.
Was there some point in the tranny removal process that the rest of the ATF comes gushing out? I just don't want a big oil spill in my garage and want to be ready. Thanks Cebby
Old Mar 20, 2006 | 11:51 AM
  #404
Cebby's Avatar
I haven't seen it yet, but that doesn't mean it still can't happen. The torque converter is full of fluid as is the transfer case (since it shares fluid with the trans on the A340H). I'm figuring tipping the assembly up on end should help it drain. I only pulled the drain plug - didn't even drop the pan - but I did stick the plug back in after I let it drain overnight initially. There's a chance more fluid is in the pan now - I'll pull the plug next time I'm down there.
I've found that the restaurant bussing pans work well for keeping fluids off the floor.
Old Mar 20, 2006 | 02:02 PM
  #405
brandontrek's Avatar
giving mad props to cebby for being "the man"....next time i am out that way i will shoot you a pm...
i still think your runner would be complete with a set of my wheels on it...woot woot....
Old Mar 20, 2006 | 03:00 PM
  #406
mt_goat's Avatar
Hey Cebby, how did you get these wires disconnected?
http://community.webshots.com/photo/...42310107ZROrMc
http://community.webshots.com/photo/...42310107jgaaDG
They both are on the drivers side of the 3.0 tranny/TC and have a little rubber boot . The wires continue through inside the tranny without any plug.
Old Mar 20, 2006 | 03:28 PM
  #407
Cebby's Avatar
Those don't go "into" the trans as far as I remember. There is a junction. As you can see, I dropped my trans without removing those. There were a few plugs on top of the bellhousing also (maybe for those items?).
Old Mar 20, 2006 | 03:34 PM
  #408
Cebby's Avatar
I thought I had a better shot of this (when I pulled the motor forward to get the BH bolts). You can sort of see the wiring coming down over the top of the trans and down the passenger side of the bellhousing. Look at lower edge of the pic in the center.
The only plug I pulled from the trans (IIRC) was the big rectangular one by the linkage connection. Everything else had a connector inline with the harness elsewhere.
Old Mar 20, 2006 | 04:28 PM
  #409
Cebby's Avatar
Well, the idea of removing the guts of the fan oil pump to turn it into an idler pulley seemed simple enough. Little did I know what I was in for. Every puller I tried was ineffective to remove the pulley. So I finally go over to the shop press and have at it.
Good news and bad news. Good news is that I got it off. Bad news is that I pringled the pulley in the process. The pulley is unusable.
So, I initially set out to find an idler assembly that bolts into the same spot. This is available on some models of 1UZ - namely the models that have electric fans. I was told LS400's, but I have yet to confirm that.
Anyway, here's the item I'm referring to:
The offending pulley...
The whole unit:
With all the other stuff stripped off:
It's off - can't tell from the pic, but the pulley is fubar.
Here's what's inside:
For reference, this pulley was right above the crank pulley:
It turns out that some of the folks on the Lextreme forum have just removed this item and are running a shorter belt. The only potential issue is that the crank pulley then only has about 30% wrap on it down from maybe 50%+. I'm concerned about what might happen with water crossings and belt slippage - plus if I add a higher output alternator for a welder or want to add a supercharger, I might have issues with belts slipping. I'm scouting for a pic of the idler to #1 see if I can locate one or #2 see if it's possible to fabricate something.
Old Mar 21, 2006 | 04:07 AM
  #410
mt_goat's Avatar
Thanks Cebby that helps alot, they must have plugs where all that bundle of wires comes together. I couldn't see one yesterday but I'll look again today, it's hard to follow which bundle is which sometimes.
Yeah a bustub would come in real handy for catching fluids
Old Mar 21, 2006 | 10:15 AM
  #411
mt_goat's Avatar
Hey Cebby, did you remove your front diff?
Old Mar 21, 2006 | 10:29 AM
  #412
Cebby's Avatar
No, just the driveshaft. The diff wasn't really in the way. FWIW, I don't run any diff drop either.
Old Mar 21, 2006 | 11:26 AM
  #413
mt_goat's Avatar
Cool thanks.
Old Mar 21, 2006 | 11:46 AM
  #414
snap-on's Avatar
I second the impossible to remove the A340H WITHOUT pulling the motor while still connected. I had the same thing on mine but i stuggled for almost a full hr trying to get them off before i said screw it and started pulling the whole nine yards out.
Had i had more overhead space i could have gotten both the motor and trans out the engine compartment with out having to fight the trans down to the ground like you had to do cebby.
Old Mar 21, 2006 | 06:52 PM
  #415
Damn the 1UZ isn't in the truck yet?>>??
I would just wire the engine to run independently and put a manual trans to it. They seem to do this all the time in Aus and they even sell wiring harnesses that you just plug in and feed it fuel and water and VROOM!
Old Mar 22, 2006 | 06:10 AM
  #416
mt_goat's Avatar
It would be nice to also have your accessories work, like AC, cruise and gauges.
Old Mar 22, 2006 | 06:26 AM
  #417
@#$* the accessories, I just want to hear that v8 come to life again!
Old Mar 22, 2006 | 07:27 AM
  #418
Cebby's Avatar
OK, you've been hired to sit next to me and hold one of those hand held fans to keep me cool.
The accessories have a little something to do with belt length - as it stands, I might have to ditch my stock LS400 belt since I'm now changing the oil pump to an idler of some sort (or nothing).
Hmmmm I haven't even thought about cruise - especially since I never used it with the 3.0. I can do that late though...
Old Mar 22, 2006 | 07:50 AM
  #419
mt_goat's Avatar
Yeah I promised my wife that we would be able to use the cruise if I got a more powerful engine I figured out with the 3.0 we can use the cruise with the OD turned off, but then we can only go 65mph. :cry:
Old Mar 22, 2006 | 10:22 AM
  #420
Hey guys I'm going to LA to pick up a 1UZ for me also. I'm going to keep things simple so that others can learn from my work and do it quick. A friend of mine is wanting me to throw in a Jericho racing transmission he's willing to donate but that's a little out of reach for most people and it would be nice to keep this whole conversion with using factory Toyota stuff. I was planning on a 5spd Toy trans but we'll see how it goes when the time comes to adapt one when I have the engine in front of me.
I can't hold out any longer.!
