All Other Toyota Swaps I4, I6, Lexus V8
1UZ-FE swap into a 1990 2dr 4runner
Old Oct 18, 2011 | 07:29 AM
Moustache's Avatar
Thanks yotasavg, not keeping the paint tho. once i get the 3.0 out im painting the whole truck matte brown
Old Oct 31, 2011 | 07:32 PM
Moustache's Avatar
Finally installed the other head and ordered an Aisin timing belt kit which should be here in a few days.
Things are coming together, slowly but smoothly
Old Nov 3, 2011 | 07:06 AM
Moustache's Avatar
Recieved my water pump, timing belt, and idlers in the mail and got started re-installing the cams.
Old Nov 3, 2011 | 08:45 AM
tj884Rdlx's Avatar
great thread! can't wait to see this rig complete. you'll have a very unique and bad-ass truck.
wanted to share a small bit of information in case it's of use to you:
on my '90 LS400, i had a hose fail on the underside of the PS reservoir. it wasn't even a high pressure hose, but just a little thing. the hose failing allowed the fluid to leak into the alternator which is mounted right below it, and it ruined my alternator twice before i realized what was happening. afterward i was paranoid of the res. being right above the alt.
you mentioned you may customize the reservoir location, so i figured this info may be of interest to you.
good luck with your build!
Old Nov 3, 2011 | 12:10 PM
  #25
Moustache's Avatar
Thanks for your encouragement.
thats the kind of scenario i would like to avoid with using a remote res. instead of the buiilt in unit on the LS. Thanks for sharing!!
Old Nov 4, 2011 | 06:29 AM
  #26
Moustache's Avatar
More progress
Still need to order a starter, LS400 fan bracket, dist. caps and rotors
Old Jan 12, 2012 | 06:50 PM
  #27
SR5's Avatar
SR5
The most amazing build thread i have ever seen, taken strait out of my dream build ideas, and its a 2Door!!!
Old Jan 13, 2012 | 04:48 AM
  #28
Moustache's Avatar
Thanks man, I really appreciate it. between the 2 door finally dieng, buying another 4runner to daily, and finding a new place to live i havnt had much time or money to work on it.
Anybody interested in a 2010 Harley Davidson?
Old Jan 20, 2013 | 09:09 PM
  #29
toyotajoe35's Avatar
Any updates?
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
mskalmus
May 28, 2017 07:51 AM
MMA_Alex
25
Apr 18, 2017 05:07 AM
HRDC0R19
Jul 5, 2015 06:43 PM
ptb12
Jul 5, 2015 01:49 PM
