what 3.4 ecu do i have? and witch one will work on my s/c engine
Old Jun 8, 2014 | 02:35 PM
chadbdi's Avatar
I have a s/c 3.4 in my first gen but im thinking I have a 95 or 96 ecu. how do I tell what year my ecu is. and what year ecu will fit my engine harness? im looking forward to driving it but I want to make sure its right before I beat on it. any info is great. thanks chad
Old Jun 8, 2014 | 04:24 PM
JasonYota's Avatar
Look up the part number on the ECU you have.
Old Jun 8, 2014 | 04:33 PM
chadbdi's Avatar
it says its a 95 so i guess i need like a 97 or 98 ecu and see if plugs are the same or not.
Old Jun 8, 2014 | 04:38 PM
JasonYota's Avatar
I believe the plugs changed around 99 or 00.
Old Jun 8, 2014 | 04:45 PM
chadbdi's Avatar
Cool tomorrow morning ill try to track down another ecu at the local yards. I got mine out now so i can compare notes. Online says s/c is for 97 and later taco. So ill look for 97 -00.
Old Jun 10, 2014 | 07:16 PM
chadbdi's Avatar
update. so looked at a 98ecu and the plugs are totally different than mine. the 98 ecu has small plastic squares in the center of the plugs between the pins and mine does not. I also learned that the plugs from 95-97 are all the same, but the 95-96 plugs are grey and 97 and later plugs are white. the 95-96 ecu with grey plugs does not react properly to the boost. it starts hard and acts out of time during normal driving. so I purchased a 97 ecu from a local yard. slapped it in there and now it starts right up and seems to run better at idle. builds good boost while hammering down. drivability is the same so im happy. hope this is helpful for someone. I learned something.
Old Jun 10, 2014 | 08:27 PM
vital22re's Avatar
totally a bro
I know on 4runners,
96-97 manuals ecus are the same *2 row*
96-97 auto's are the same *4 row*
98-99 manuals and auto are the same plugs but different ecu's
and then i think 2000 and on the plugs are smaller but same between manual and auto.
Old Jun 10, 2014 | 08:52 PM
chadbdi's Avatar
crazy how many different ecu s there are. thinking about sending my extra throttle body off to get bored in the am. I found a box it will fit in today. any idea of the time it takes lc e to turn one around? also how do you like the 7th injector deal. did it make a big difference?
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
greenbuggy
Jun 28, 2015 10:40 AM
gog1968
Jun 22, 2015 05:55 AM
Edionne13
Jun 21, 2015 11:37 PM
TheManOutside
Jun 18, 2015 03:32 PM
