Runs and Drives but Hesitates and bad gas milage
Old May 5, 2015 | 01:04 PM
lsxfactor's Avatar
I have a 95 Toyota Pickup. 5 speed, 4wd. Swapped a 97 4runner auto, 4wd 3.4 into it. Converted harness from auto to manual. I have correct MAF and ECM for engine.
Truck runs and drives. slow acceleration, hesitates and bogs.
no codes
horrible gas mileage
fuel pressure is good
02 sensor reads o volts with scan tool.
Any ideas would be greatly appreciated. Thanks in advance. Working on it right now.
Old May 5, 2015 | 02:11 PM
lsxfactor's Avatar
Anyone??
Old May 5, 2015 | 10:12 PM
rworegon's Avatar
The zero volts on the O2 sensor sounds like it's not wired in correctly. The O2 sensor voltage should fluctuate.
Old May 13, 2015 | 07:12 AM
Austin Marr's Avatar
Agreed. Check your 02 sensor wiring. If it's reading 0 volts it's like running without an 02 sensor. You have some sort of wiring correct since you aren't throwing a code but it's got to be missing something somewhere
zd92655
Mar 6, 2022 12:58 PM
91toybeater
Dec 27, 2015 07:46 PM
WI Girl
Jun 25, 2015 03:45 AM
dlotoy4runner
Jul 11, 2002 08:24 PM
BTOWN4RUNNER
13
Jun 10, 2002 06:33 PM
