Runs and Drives but Hesitates and bad gas milage
I have a 95 Toyota Pickup. 5 speed, 4wd. Swapped a 97 4runner auto, 4wd 3.4 into it. Converted harness from auto to manual. I have correct MAF and ECM for engine.
Truck runs and drives. slow acceleration, hesitates and bogs. no codes horrible gas mileage fuel pressure is good 02 sensor reads o volts with scan tool. Any ideas would be greatly appreciated. Thanks in advance. Working on it right now. |
Anyone??
The zero volts on the O2 sensor sounds like it's not wired in correctly. The O2 sensor voltage should fluctuate.
Agreed. Check your 02 sensor wiring. If it's reading 0 volts it's like running without an 02 sensor. You have some sort of wiring correct since you aren't throwing a code but it's got to be missing something somewhere
