Which radiator for 3.4 swap, 88-89 4Runner/88 Truck V6
Old Feb 10, 2012 | 12:05 PM
DeathCougar's Avatar
PLEASE READ THIS CAREFULLY BEFORE REPLYING!!
Anyone who has done a swap on a STOCK 1988-1989 4Runner, or 1988 Truck that was originally a V6, which radiator did you use?
Stock OEM radiator has a 45 degree inlet which makes using the OEM 3.4 hose impossible.
Aftermarket radiators that I am finding have either the 45 degree inlet, OR the radiator cap on the side of the top, instead of centered. Later model (90+ 4Runner and 89+ Truck) radiators don't seem to work because the hood hits the cap.
I am not interested in Radiator drops (which I did on my 87) nor body or hood lifts or hood trimming. I know it can be done, I have seen it!
Or....does anyone know of a radiator shop in the greater seattle area who can modify my radiator?
Old Feb 10, 2012 | 01:15 PM
Not sure why this double posted.....fixed now!
Old Feb 10, 2012 | 07:06 PM
waskillywabbit's Avatar
We used an aftermarket 2nd gen radiator. Still has a very slight bend to it but no way close to hitting the hood.
:wabbit2:
Old Feb 10, 2012 | 08:38 PM
vital22re's Avatar
totally a bro
Brass tank means cut and make the radiator inlet obey your desires.
Old Feb 11, 2012 | 06:02 AM
I thought about that but the stock radiator had seen the milkshake too.
:wabbit2:
Old Feb 12, 2012 | 06:47 PM
Greg_Canada's Avatar
This is the one i used.... Name:  Engineinstall064.jpg
It said 88-89 4runner v6.... It was shaped different than my original rad and i had to drill some holes in the mounting tabs to drop it an inch or 2.... It may be a 90-95 rad....
Old Feb 12, 2012 | 08:23 PM
vital22re's Avatar
totally a bro
So we found out that the brass tanked radiator had steel stamped in outlets. We were planning on just cutting and soldering the brass but as we were wire brushing to clean, we discovered that it was a steel outlet. This makes it a lot easier now so we just cut the outlet rotated it to make it straight and welded it in place. The upper hoses look great now.
Old Feb 12, 2012 | 09:09 PM
Yep yep.
To "conclude" this thread, he is absolutely correct! Time will tell if it will leak or not, but it appears to work for now.
Old Feb 16, 2012 | 08:03 PM
theMonch's Avatar
Sorry, late to the party on this one, but for future reference for others. I used a stock replacement from Rockauto.com. for my 88 4runner. It was an aluminum core with plastic tanks, so this allowed me to use the "red" long life fluid that was in the 3.4 from the factory, since the 3.4s original T100 radiator was the same construction. I used the following hoses from NAPA.
Upper: 7559 (cut to fit)
Lower: 7571 (used unaltered)
Old Feb 17, 2012 | 06:37 AM
slacker's Avatar
I posted this in another thread , but see this is basically the same , so thought I should post it here as well
just to let people know .. Precision 4x4 center (toyotafiberglass.com) offers an excellent rad replacement .
brass and copper , complete dimentions measure , 2 3/4 core" X 22.5" X 22.5" accepts a 22re or 3.0 L shroud
excellent cooling charistics .. I have one in my /83 Trekker , and it's perfect .
with a electric fan
Our Price to the lower 48 , including shipping $289.00 (business addresses only)
Canada - $299.00
compare OUR pricing with rock auto or rad barn !!
basically EXCELLENT for ANY engine swap into a toyota truck ...
currently 12 in stock
watch our vendor area for launch of our new Precision 4x4 Center web site
I have better pics , and will post asap
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
vasinvictor
Jan 20, 2016 12:39 PM
94whiterunner
Sep 22, 2015 07:25 PM
Edionne13
Jun 21, 2015 11:37 PM
duckhead
3.4 Swaps
7
Jun 18, 2015 06:54 AM
