no spark searched and searched
Old Jul 8, 2015 | 11:19 AM
exporunner's Avatar
Get a hold of some TIS wiring details for you ecm and check you ign switched power to your ecm and ignitor.... it sounds like you have a bad connection somewhere. I had a similar issue with my swap and found that the positive terminal on my battery needed to be replaced (I wasn't getting a reliable 12v to me ecm and ignitor). Once it started it ran fine though.
I know wire is a pain in the @$$ to check but you will want to verify your connections. I STILL have a bug in mine somewhere and my rig occasionally wont turn over without a jump even with a full battery.
Old Jul 20, 2015 | 09:20 AM
pineymudder's Avatar
I did check for b+ at the igniter and coils. 12v is there, the coil actually loses negative wich breaks the field and coil fires. Also i read were streached timing belt cause long crank problem. Cam and crank sensors not reading at exact right time. My engine had 140k on the clock and i didnt know the maintenance history cause i baught it from a body shop alread crashed. The timing belt looked in good condition when i had the cover off while in the stand and i didnt want to add any unnecessary variables on my swap startup so..... I do have a new belt and water pump on the shelf, and i done the job plenty of times on different 3.0's. Might as well try that just to rule it out. Ill keep everyone posted.
Old Oct 31, 2015 | 05:59 AM
I did change the timing belt, still same problem. The last thing i had to do before i braught it to a friend of a friend (toyota master tech) i need to replace my knock sensor harness. Well i tried to start it and was cranking real slow... terminals and starter were very hot, so i swaped out the starter with a good looking used starter i had in the shed. Guess what.... truck has been starting great all week!! It even turns over way faster then i remember, it sounds like a honda civic starter now. I cant explain it but i dont care, as long as it starts like a normal vehicle now!!
Old Dec 18, 2017 | 09:47 AM
Rocky1's Avatar
Thanks for this thread. Helps me with my current P1300 problem. So much to check out, but I see one needs to be patient!
montanatruck
Feb 26, 2017 07:07 AM
justdifferentials
Just Differentials
Aug 30, 2015 08:42 PM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
exporunner
3.4 Swaps
Aug 3, 2015 06:10 PM
4Runnin2000
Jul 29, 2015 06:09 PM
