Homeless vaccuum line port + small random wire
Old Apr 22, 2015 | 05:26 PM
Unbrakeable's Avatar
Finishing my swap, but it seems I never marked these two little random parts. The first is a vac line off the back of the block, second is a random little black box under my master cyl.
1995 v6 4runner 4x4. Here are the photos:
Attached Thumbnails Homeless vaccuum line port + small random wire-img_6148.jpg   Homeless vaccuum line port + small random wire-img_6149.jpg
Old Apr 22, 2015 | 05:28 PM
the vac line
Attached Thumbnails Homeless vaccuum line port + small random wire-img_2866.jpg
Old Apr 22, 2015 | 05:31 PM
Another of the vac line
Attached Thumbnails Homeless vaccuum line port + small random wire-img_2867.jpg
Old Apr 22, 2015 | 09:17 PM
vital22re's Avatar
totally a bro
donor must be early tacoma or t100. The ectrical connector is missing the part that bolts to the block its a noise filter.
the vacuum line is for the fuel pressure regulator "system" it needs a vacuum source from the small vacuum line above it I believe... But you might want to just google vacuum routing for what ever the donor was.
Old Apr 22, 2015 | 09:26 PM
Noise filter? Interesting. So if I get a spade connector and round connector stick it onto the block all my noises should be filtered?
Im digging through the vac diagram now. Donor was a 95.5 taco.
Old Apr 22, 2015 | 09:40 PM
Reading up on the 3.4s apparently they "did away" with the EGR stuff, so I'm a bit confused on this diagram. I certainly don't have an EGR valve. Going to look harder for a better diagram.
Attached Thumbnails Homeless vaccuum line port + small random wire-0900c15280060e55.gif
Old Apr 23, 2015 | 05:19 PM
slacker's Avatar
you don't need it .. it is to supress the noise from the distributor to the radio .. 3.4 does not have a distributor
Old Apr 23, 2015 | 06:27 PM
slacker's Avatar
Kyle
just got your email .. glad to help .
that port is for the fuel evap system . I don't have my "notes" in front of me at the moment to tell you exactly how to route it .. I'm sure some one on here will chime in
: > edit ..vital22re said it all above
MO transplant
Apr 23, 2023 11:58 AM
Sep 4, 2015 09:27 AM
87turboPA
Jul 12, 2015 07:49 AM
88runnergomas
Jul 9, 2015 01:12 PM
87turboPA
Jul 9, 2015 05:58 AM
