Getting ready to cut the hood and install hood scoop and...
Old Mar 18, 2012 | 06:05 PM
spinyard's Avatar
the hood closes just fine without needing to cut a hole! I just cut out part of the reinforcement ... Awesome makes it even more of a sleeper. I wonder why the difference in engine heights. I do not have a body lift either...
Attached Thumbnails Getting ready to cut the hood and install hood scoop and...-hood1.jpg   Getting ready to cut the hood and install hood scoop and...-hood2.jpg   Getting ready to cut the hood and install hood scoop and...-hood3.jpg
Old Mar 18, 2012 | 08:13 PM
spinyard's Avatar
66 views and no one else didnt have to cut their hood?
Old Mar 18, 2012 | 08:24 PM
vasinvictor's Avatar
You're the first I've heard of, personally. Must be shorter height engine mounts in only a select few 4runners.
Old Mar 19, 2012 | 03:02 AM
4x4runr's Avatar
I read of another person doing the same thing.... Grats to you!
Old Mar 19, 2012 | 08:15 AM
Ride4Fun's Avatar
I did the same thing on my 92 4Runner. No hole, just the braces. Actually didn't even cut the braces to start with but noticed later that they were rubbing a little.
Old Mar 19, 2012 | 10:33 PM
calipatient's Avatar
I only cut the braces at first and it caused 2 very small dents in the hood... granted I have the S/C and the dents were caused by the nose of the S/C.
If I didn't have it I think it would have cleared just fine!
No body lifts.
Old Mar 20, 2012 | 08:17 AM
Fernley1's Avatar
On mine 3.4 swap, I just cut out the brace for the hood, and it closes. No body lift.
Old Mar 20, 2012 | 08:20 AM
I'm glad this is getting out. When I was researching this swap all I could find was that you needed at least a 1" BL to clear. Lots of differing info out there.
Old Mar 20, 2012 | 06:04 PM
donomite49's Avatar
the ors instructions said that the early models, first/second gens have less clearance than later models. my 88 looks like the hood will be cut even before i charge it. i just hope the mustang scoop will clear the sc, will find out when i get there.
Old Mar 27, 2012 | 07:54 PM
lil_no's Avatar
I didn't cut anything and no body lift. Hood on my 93 closes fine. There are a couple of spots where the throttle cable and a vacuum hose at the rear of motor rubbed thru the insulation.
Old Mar 27, 2012 | 10:07 PM
tobryant07's Avatar
Sweet maybe I can save a few bucks and just cut out a little metal. Thanks for the info.
Old Mar 29, 2012 | 04:56 AM
theMonch's Avatar
Definetly Varies
From what I came across when I was researching, it looked like the 2nd gen trucks/4Runners had more room and it was a case by case if cutting just the braces works, or if you have to go the hole/scoop route.
My 88 needed a pretty big hole that the scoop barely covered.
88sasturbotoy
Jan 30, 2026 01:57 PM
raptor510
Feb 17, 2017 07:11 AM
DrZero
18
Jul 24, 2015 11:31 PM
crashburnoveride
Jul 10, 2015 06:39 AM
bryan34w
Jul 6, 2015 05:53 PM
