Can Oil Pan Baffle from 3.0 be used on 3.4?
Old Feb 17, 2011 | 06:55 PM
lil_no's Avatar
Hi currently in process of swapping the oil pick up and pan from the 3.0 out of my 93 4runner. During all of my reading, I've seen where everyone has cut a hole in the Oil pan baffle from the 3.4L. My question is can the baffle from the 3.0 be used? I put it on and everything appears to line up without having to cut anything. Is there a reason for not using the 3.0 baffle? Just curious, like I said haven't seem anyone use it.
I will attach pic.
Thanks in advance for your guidance.
Attached Thumbnails Can Oil Pan Baffle from 3.0 be used on 3.4?-p2170926.jpg
Old Feb 17, 2011 | 07:22 PM
deyzin's Avatar
I used everything from the 3.0.
Old Feb 18, 2011 | 09:34 AM
lil_no's Avatar
Ok, Thanks for the reply deyzin. Greatly appreciated.
Old Feb 19, 2011 | 07:24 AM
dntsdad's Avatar
Lots of people have used the 3.0, but I went for the 3.4 baffle because the sandwich mount of the 3.0 just looks destined to leak. The 3.4 one gets everything inside the pan and there is only one seal to leak rather than two.
Old Feb 19, 2011 | 09:30 AM
lil_no's Avatar
Thanks, dntsdad. I was working on things last night and kinda came to that same conclusion. It makes a lot of sense to just modify the 3.4 baffle to keep everything inside the pan and then there's only one seal between block and pan.
Thanks again for response.
XtraCab
Apr 12, 2020 05:25 AM
Amer
3.4 Swaps
19
Jun 5, 2017 10:43 AM
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
Coreyr384
Jul 10, 2015 11:13 AM
