Calling all guru's HELP!
Old Jan 3, 2021 | 06:23 AM
Shane Carrington's Avatar
Okay so about a week ago I had my swap far enough along to give it a test bump so after turning it over a few times if fired off and I immediately shut it off ,(no radiator ,or exaust ).Thrilled thinking that everything was going my way I finished in its entirety everything but the hood so I decide to crank it up and back out of the shop and heres where the fun has begun ,my truck will fire off almost immediately everytime but dies within about 2 seconds.Ive discovered that it loses injector pulse .At first I thought maybe it was a mistake in the wiring and the ecm wasn't getting the signal that the engine was running but even if I continue holding the key in the start position it still loses injector pulse after about 2 seconds until I release cut it off and try again.ive tested cam and crank sensors pulled new wires for both cleaned all grounds and even added some extras,changed the core relay to a Bosch ,I'm using the ecm from the automatic 4 runner 2wheel drive 3.4 ltr in my 1990 3.0. manual truck .4x4 any suggestions would be greatly appreciated this is my work truck and very much needed .Also when I scan it I get shift solenoid codes which were expected and I also get p0100 and p0110 and p1300 I've checked and double checked my wiring and even installed new from the sensors back to the ecm but still the codes return
Old Jan 19, 2021 | 06:34 AM
Tropiganda's Avatar
I am having similar issues. Haven’t been able to check codes but almost the exact same symptoms.
Old Jan 28, 2021 | 09:44 AM
Tropiganda's Avatar
My issue was a broken tooth on the crankshaft timing sprocket.
Old Jan 28, 2021 | 11:23 AM
5 Fists's Avatar
Good on you for reporting back Tropiganda! Hopefully the OP circles back around as well.
kraptastic_k
Apr 2, 2024 07:18 AM
Streetrod19772000
3.4 Swaps
Jan 12, 2015 11:03 AM
canadianjerkey
7
Aug 9, 2014 10:45 AM
P7M13
Feb 21, 2014 03:50 PM
adb21
Jan 4, 2014 07:06 AM
