Build your own 3.4 crossover pipe
Old Apr 8, 2008 | 02:55 PM
RanchoToyotaTruck's Avatar
Here are a few of my crossover pipes
also built using most of the stock parts
Old Apr 19, 2008 | 07:22 AM
slacker's Avatar
I built mine for $30.00 ( + consumables , and my time )
Old Apr 20, 2008 | 01:14 AM
Lysmachia's Avatar
Originally Posted by Elvota
Wonder why the flex joint was eliminated? I was under the impression this allowed the crossover to flex or expand along with the heads.
I happen to have a older 3.4 crossover for sale... in perfect shape... if someone is looking for the flanges and such.
How Much Steve? I assume that will fit fine with my 1997 3.4 in my 2nd Gen...
Now that the weather is much nicer We are ready to begin the surgery. At least I already have the 3.0 pulled and out of the way!
Old Nov 12, 2008 | 02:56 PM
syber_kowboy's Avatar
Are those stock flanges with custom pipes and a stock flex joint? Did you buy the pipe and shape it yourself? Thanks
Old Nov 12, 2008 | 06:32 PM
  #25
Lysmachia's Avatar
God I forgot about how awesome this thread was.....
Old Nov 24, 2008 | 10:12 AM
  #26
Jason4X4's Avatar
Cool...
Old Jan 17, 2009 | 08:07 AM
  #27
mt_goat's Avatar
Some of us have had a problem with the crossover wrapping. Apparently it allows the metal to get too hot and causes the pipe to crack. This is probably made much worse by using too much overlap with the wrap and or supercharging the engine. Ceramic coating seems to be a better option.
Pic of my crossover failure, note the flaking of the metal, this was inside too resulting in the pipe thickeness decreasing more and more until a crack developed (or that's my theory anyway) It was very thin where it got too hot, it must have been very close to molten because it scaled over and got flaky like molten steel gets. Some would confuse this for rusting out, but I'm sure it wasn't from rust. I was careful to always run the engine for a while after washing the truck to evaparate any water from the wrap.
Old Jan 17, 2009 | 08:29 AM
  #28
neoworm0's Avatar
Mt. Goat, have you heard of anyone who has had thier xover ceramic coated and having it crack? I had mined ceramic coated but I'm wondering now if I should just try to beef up that joint before I go ahead and put my motor in. This problem seems to be getting more common.
Opinions?
Old Jan 17, 2009 | 08:43 AM
  #29
mt_goat's Avatar
Opinions?
I can't remember anyone having a failure with a ceramic coating. At least make sure you support the crossover with a brace at the bell housing, something like this:
And put a flex coupling after that (before the cat).
Old Jan 28, 2009 | 05:12 PM
  #30
Lysmachia's Avatar
Getting ready to do this. Man it is so exciting to finally get my 3.4 in there!
Old Jan 29, 2009 | 04:09 AM
  #31
mt_goat's Avatar
Go Molly go
Old Feb 25, 2009 | 04:59 PM
  #32
904_runner's Avatar
NICE!!!!
Im about to start one i think...
Glad i found this thread.
Old Feb 25, 2009 | 07:50 PM
  #33
spanish-road's Avatar
I know that heat wrap would damage the pipe and welds, since it would cause mass build-up of heat.
Old Mar 17, 2009 | 07:19 PM
  #34
904_runner's Avatar
Okay so with that being said how many people used the wrap over it??
Would you recommend it or not???
Im going to start mine real soon
Old Mar 18, 2009 | 04:14 AM
  #35
mt_goat's Avatar
Just spend the extra $40 or so and get it ceramic coated.
Old Mar 18, 2009 | 06:28 AM
  #36
okie81's Avatar
As stated above, wrapping get's things hot. I tried header wrap; no bueno.
Old Mar 23, 2009 | 08:37 PM
  #37
slcpunk74's Avatar
So is it not possible to use the log style exhaust manifolds with a Y under the trans? Just curious because Im getting ready to start my swap.
Old Mar 23, 2009 | 08:51 PM
  #38
neoworm0's Avatar
By log do you mean "stock"? If so. Yes it is. You need to buy headers.
Old Mar 23, 2009 | 09:04 PM
  #39
slcpunk74's Avatar
damn! well i guess the prerunner will just be that much more fun.
Old Mar 23, 2009 | 09:06 PM
  #40
904_runner's Avatar
Got mine done.. remember guys to sort of tuck that exhaust flange close to the transmission so it doesn't interfer with the frame.. ill have to modify mine some how in order to get this done...
I did get it done though..
Thanks for the write up!
