automatic transmission
Old Sep 19, 2014 | 04:27 PM
slacker's Avatar
hey all ...
installing a 1995 T100 3.4L auto , into a /94 3.0L auto . truck .
have a question .
the /94 has 4 shift solenoids and theT100 only has 3 . not quite sure how to wire this ? anyone have any ideas ?
/94 EWD ATM tranny
95 T100 EWD tranny
Old Sep 19, 2014 | 04:42 PM
vital22re's Avatar
totally a bro
L4. Since the 3.0 auto has the transfer case built into it, there is a seperate solenoid for the Low 4 function. I join the 3.0 autoharness right before the rubber ribbed section at the engine side of the harness.
Old Sep 19, 2014 | 04:54 PM
slacker's Avatar
so this is what # 4 is for ?
Old Sep 19, 2014 | 05:21 PM
vital22re's Avatar
totally a bro
Yes, if you go to the system outline for the ECT EWD it offers an explanation. I rig up a relay to send power to the solenoid when L4 is selected. Keep in mind to explain to customer that he needs to follow the L4 shifting instructions as you bypass the ecu deciding when its safe to shift into L4.
Old Sep 21, 2014 | 10:19 AM
slacker's Avatar
thanks i'll have a look at that ..
also , if you don't mind me asking ... the 94 has a electronic speed sensor instead of a speedo cable .. are you replacing that with the cable an cable driven speedo ? , from what I can see , the t100 is cable driven
Old Sep 23, 2014 | 04:14 PM
slacker's Avatar
must have had a "brain fart" or something .... I don't know why this install intimidated me so much , but I got all figured out once I actually thought about it
thanks for your help vital22re
Old Sep 25, 2014 | 11:18 PM
vital22re's Avatar
totally a bro
No worries, I've done a few of these and try to help others when I can.
Also depending what it goes into, if it was fuel injected then there is a speed signal from cluster that goes to ecu. You match that up as the 3.4 has the same function. Then you either keep the cable speed sensor if it was cable, or if your rig has electric speedo you wire it back up.
4x4-runner
Dec 27, 2016 01:58 PM
BeMiceElf
Oct 10, 2015 09:40 PM
eggens
Sep 5, 2015 12:16 AM
kelly1450
Sep 2, 2015 12:29 PM
Hugh_Mann
Aug 31, 2015 04:02 AM
