Anybody done a 2WD 3.4 swap?
Old 06-19-2012, 08:49 AM
waskillywabbit's Avatar
Your scanner?
:wabbit2:
Old 06-19-2012, 09:04 AM
anthony1's Avatar
The OBDII scanner.
Old 06-19-2012, 09:25 AM
So your cluster speedo doesn't work now?
:wabbit2:
Old 06-19-2012, 09:30 AM
anthony1's Avatar
it works fine. I kept cable one...the ecu gets the speed signal from the cluster. I forgot what pin number it ws from the IE connector...
Old 06-19-2012, 09:36 AM
  #25
Thanks Anthony. That will make life easier.
:wabbit2:
Old 06-19-2012, 09:39 AM
  #26
Hold on a second.
My cluster is mechanical. My donor Tranny has electronic.
Is that how yours is?
Maybe I need a Red Bull.
:wabbit2:
Old 06-19-2012, 10:05 AM
  #27
anthony1's Avatar
It's pin 20 on IH1 for my truck. I connect that to the pin 20 IE1 to 3.4 ecu. sp1 pin 12A.
Old 06-19-2012, 10:06 AM
  #28
anthony1's Avatar
oh...I have cable speedo to mechanical instrument cluster to ECU.
Old 06-19-2012, 10:16 AM
  #29
anthony1's Avatar
You might need to swap the inst. cluster from a limited auto. Those have the elec. Speed signal feed.
If you can swap to gear driven one on the transfer side, that would be better. That way the odometer value doesn't change. I have a brand new speedo cable for 95 4runner if you need one. Maybe contact Marlin about the speedo gearfor auto.
Old 06-19-2012, 10:23 AM
  #30
Yeah. We were originally thinking the easiest way to solve was a cluster swap.
:wabbit2:
Old 06-19-2012, 01:02 PM
  #31
anthony1's Avatar
Btw, got any 1/2 ton T100 ecu that doesn't have EGR monitor?....
Old 06-19-2012, 01:12 PM
  #32
totally a bro
Staff
vital22re's Avatar
I don't know if you're able to swap the electric sensor out for a mechanical one or the other way so you can match mechanical to mechanical speedo, but i was able to do that on the old 3.0 trans.
Old 12-17-2012, 11:22 AM
  #33
l3fty's Avatar
The trouble with trying to use the electronic speedo, is that because it's not 4wd. The signal comes from the ABS unit instead of the trans.
Old 12-17-2012, 11:32 AM
  #34
Done. Completed. Finished.
Everything works just fine.
:wabbit2:
Flying91
45
04-11-2024 04:39 PM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
WellsR
12
07-31-2015 03:27 PM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
94whiterunner
07-12-2015 07:15 PM
Quick Reply: Anybody done a 2WD 3.4 swap?
