Anybody done a 2WD 3.4 swap?
Old Jun 19, 2012 | 08:49 AM
waskillywabbit's Avatar
Your scanner?
:wabbit2:
Old Jun 19, 2012 | 09:04 AM
anthony1's Avatar
The OBDII scanner.
Old Jun 19, 2012 | 09:25 AM
So your cluster speedo doesn't work now?
:wabbit2:
Old Jun 19, 2012 | 09:30 AM
anthony1's Avatar
it works fine. I kept cable one...the ecu gets the speed signal from the cluster. I forgot what pin number it ws from the IE connector...
Old Jun 19, 2012 | 09:36 AM
  #25
Thanks Anthony. That will make life easier.
:wabbit2:
Old Jun 19, 2012 | 09:39 AM
  #26
Hold on a second.
My cluster is mechanical. My donor Tranny has electronic.
Is that how yours is?
Maybe I need a Red Bull.
:wabbit2:
Old Jun 19, 2012 | 10:05 AM
  #27
anthony1's Avatar
It's pin 20 on IH1 for my truck. I connect that to the pin 20 IE1 to 3.4 ecu. sp1 pin 12A.
Old Jun 19, 2012 | 10:06 AM
  #28
anthony1's Avatar
oh...I have cable speedo to mechanical instrument cluster to ECU.
Old Jun 19, 2012 | 10:16 AM
  #29
anthony1's Avatar
You might need to swap the inst. cluster from a limited auto. Those have the elec. Speed signal feed.
If you can swap to gear driven one on the transfer side, that would be better. That way the odometer value doesn't change. I have a brand new speedo cable for 95 4runner if you need one. Maybe contact Marlin about the speedo gearfor auto.
Old Jun 19, 2012 | 10:23 AM
  #30
Yeah. We were originally thinking the easiest way to solve was a cluster swap.
:wabbit2:
Old Jun 19, 2012 | 01:02 PM
  #31
anthony1's Avatar
Btw, got any 1/2 ton T100 ecu that doesn't have EGR monitor?....
Old Jun 19, 2012 | 01:12 PM
  #32
vital22re's Avatar
totally a bro
I don't know if you're able to swap the electric sensor out for a mechanical one or the other way so you can match mechanical to mechanical speedo, but i was able to do that on the old 3.0 trans.
Old Dec 17, 2012 | 11:22 AM
  #33
l3fty's Avatar
The trouble with trying to use the electronic speedo, is that because it's not 4wd. The signal comes from the ABS unit instead of the trans.
Old Dec 17, 2012 | 11:32 AM
  #34
Done. Completed. Finished.
Everything works just fine.
:wabbit2:
Flying91
45
Apr 11, 2024 04:39 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
WellsR
12
Jul 31, 2015 03:27 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
94whiterunner
Jul 12, 2015 07:15 PM
