91 4runner 3.4 swap no fuel??
Old May 20, 2013 | 10:27 AM
Jesse Fullerton's Avatar
Exclamation 91 4runner 3.4 swap no fuel??
Hi there, so this morning I drove my 4runner to work and it ran fine. I came back out about 30 mins later and it wouldn't start, heres what I've done so far.
1. Good Spark
2. Cracked the fuel line and had No pressure even while cranking.
3. EFI fuse is good and getting power
4. No power to fuel pump from wiring harness.
5. EFI Relay clicks once when key is turned on??
Any help would be greatly appreciated I am stumped here. Why would it all of a sudden just quit? I dont know much about the functions of the relay So if any of you have any advice please chime in.
P.S. This swap has been in for about 3500 miles now and everything has been running fine.
Thanks
Old May 20, 2013 | 06:42 PM
auassay's Avatar
Fuel pump?
As it is a 91, there is a high probability of the pump failing. You can apply +12 to the pump harness and see if it kicks on. If it does there is probably a short between the relay and the pump.
Old May 20, 2013 | 06:45 PM
Well I feel like an idiot, first thing I did was go through all the fuses. Replaced efi relay and COR with a buddys and still nothing. Started tracing all the wires finally got back to the fuse block where guess what i found?? A blown fuse!
I guess this could be a quick reminder for everyone else as well as myself CHECK ALL FUSES TWICE before you really start tearing into things..
Old May 21, 2013 | 09:25 AM
anthony1's Avatar
That makes me wonder why the fuse was blown in the first place......
Old May 21, 2013 | 09:32 AM
I know... I just bought this runner a few months ago with the swap already done. I'm getting ready (doing my research) to go through all the wiring and redo it. Also went wheeling in it a few weeks ago and was trying to go up this steep rocky ridge and every time I would get about 1/2 way up and as soon as I hit that ledge hard the efi fuse would blow and kill my engine? So my guess there is a little short somewhere and I got to find it. Also when I replaced my cor it was rusted to gummy bears.
Old May 21, 2013 | 09:33 AM
The runner.
Old May 21, 2013 | 01:49 PM
anthony1's Avatar
That could mean that it was submerged? Is there any signs of water damage?
Old May 21, 2013 | 01:54 PM
No signs of water besides that...
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
vasinvictor
Jan 20, 2016 12:39 PM
94whiterunner
Sep 22, 2015 07:25 PM
Edionne13
Jun 21, 2015 11:37 PM
duckhead
3.4 Swaps
7
Jun 18, 2015 06:54 AM
