90 4runner 3.4 swap injectors not firing
Old Feb 22, 2014 | 05:53 PM
coledevries's Avatar
Question 90 4runner 3.4 swap injectors not firing
heres the scoop.
1990 4runner sr5 v6 manual
donor engine from a 1998 tacoma auto.
engine is all in a few more wires to hook up for alt, 4wd, gauges, tranny,
ive hooked up the basic wires for the computer.
starter is hooked up,
ig2 -ig2 is hooked up.
computer is bolted to the body temporarily.
the g-y from the COR - pin 23 on the e12 plug (e5 tacoma)
i bought a 4x4 mt 5vz ecm so i dont have to worry about the tranny codes.
i havent hooked up the obd2 port yet.
now i have spark, i have fuel, and power to the injectors,
i put my power probe on the ground side of the harness, and see if the light flickered green while cranking but i saw it flicker once and not again.
ill try the noid light next.
my main question is what does it take for the ecm to ground the injectors
and complete the combustion cycle?
cole
Old Feb 26, 2014 | 06:33 PM
does anybody know if the fc pin has to be hooked up?
Old Feb 27, 2014 | 08:53 AM
SacRunner's Avatar
"FC" stands for "Fuel Control" and controls the COR, so yes, you need to have it connected.
Old Feb 28, 2014 | 06:18 PM
dntsdad's Avatar
Talking
Just hook up everything
Old Mar 5, 2014 | 10:29 PM
turns out the batt pin wasnt hooked up.
its now firing but dies after a second, the cor is wired properly.
sounds like it fires then dies and backfires through the intake
Old Mar 6, 2014 | 01:07 AM
vital22re's Avatar
totally a bro
hot wire the fuel pump and see if it stays running. If yes, you don't have FC wired properly.
Old Mar 9, 2014 | 07:49 PM
it runs fine now!
turns out when i read somewhere that you hook the g-y wire to the the 23 pin on the e5 plug
because of this all the other powered sensors like maf and tps didnt have a voltage, and it wouldnt stay running.
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
coryc85
Sep 9, 2015 06:24 AM
Cplmike
Jul 8, 2015 08:47 PM
HRDC0R19
Jul 5, 2015 06:43 PM
