88 4runner 3.4l swap
Old Jul 2, 2013 | 06:00 AM
  #161
Moto260's Avatar
2000 toyota tacoma m/t 3.4l engine/harness and ECU. I do have an obd2 but don't think it'll read until my engine at least starts? It's capped. Ill try some starting fluid. And ill check the spark tonight when I get home. Sure sounds like she's sparking. Possibly the 3.0 fuel pump. I double checked the grounds. They all seem solid. She just needs a real good run through. Thanks for the help guys. Ill let u know tonight how it goes
Old Jul 2, 2013 | 06:01 AM
  #162
Moto260's Avatar
Maybe the obd2 will read accually. Ill plug in the scanner with my key turned tonight
Old Jul 2, 2013 | 04:21 PM
  #163
Moto260's Avatar
Tried starting her with brake clean. Started for a few seconds so she's gotta have spark. Plugged in my scanner. Only one code P1300 igniter circuit malfunction. Need to trouble shoot on that
Old Jul 2, 2013 | 05:41 PM
  #164
vital22re's Avatar
totally a bro
My bet is your MAF/COR. Something isn't telling the pump to turn on. You can temporarily "hotwire" the fuel pump to stay on with ignition and see if it'll stay running.
Old Jul 2, 2013 | 06:57 PM
  #165
Moto260's Avatar
Ok so did a little reading. Start here then go to this pretty much. First thing. Ignition coils. So pretty much just checking my spark. 1-5 sparks. 6.....nothing. Swapped over my #1 cylinder coil pack with #5 cylinder coil. 2 sparks go to 6 still no spark. It seems like wiring. My 3.0 ran on 5 cylinders though. I don't know. Back to the books.
Old Jul 3, 2013 | 03:42 PM
  #166
Austin Marr's Avatar
I'm with vital22re on this one I think.
Old Jul 3, 2013 | 04:44 PM
  #167
Moto260's Avatar
Hmm so I should try and Hotwire my fuel pump? Ill read up on that and see if I can't figure her out.
Old Jul 3, 2013 | 08:48 PM
  #168
Moto260's Avatar
Alright. I'm gonna find a guide to Hotwire my fuel pump. Worth a shot. The #6 plug not firing is something different but not why my trucks not starting. I sprayed a ton of brake clean in my intake today and I could probably drive it with brake clean. No fuel getting in for sure. Ill let u guys know how it goes when I get the chance to get into it. Thanks for all the advice. Ya'll are a ton of help, and It's much appreciated.
Old Jul 4, 2013 | 11:52 AM
  #169
Moto260's Avatar
SHE"S ALIIIIVVVVEEEE!!!!! I started ripping off my intake to check the wiring, then i fiddled with a few things. Changed a couple Grounds around threw her back together. Cut my hood up a bit more, figured before i start trying to Hotwire my fuel pump. Give her one last crank and BAAAM! She fired up. No tachometer or Speedometer but thats alright. Drove her down the street and MAN she laggs. Feels like im runnin a subaru Brat with one cylinder hah. On to the next. She must need some real fine tuning.
<<<<<------- Soooo Stoked!
Old Jul 4, 2013 | 04:21 PM
  #170
Good to hear about it running! I can help with the tach but not sure about your speedo.
Old Jul 6, 2013 | 11:41 AM
  #171
Moto260's Avatar
Well I've got a lot of codes ill be trouble shooting so hopefully ill figure it out. Po450 Evap canister issues. Po300 multi-cylinder misfire. Po302 misfire cylinder 2 po304 misfire in cylinder 4 po306 misfire cylinder 6 then another po450. I'm either getting no spark or no fuel to one side of my engine. Maybe a bad injector. Back to spark plug testing lol
Old Jul 6, 2013 | 03:57 PM
  #172
Moto260's Avatar
No fuel on one side of truck. All my spark is good and did a compression test. All checked out good. Update u this week when I figure it out
Old Jul 6, 2013 | 10:36 PM
  #173
vital22re's Avatar
totally a bro
you can use a stethoscope to listen to the injectors to see if they are firing. If they are then they could just be clogged. Maybe you got the vent line and return lined mixed? Would be worth pulling all the injectors and having them cleaned professionally.
Old Jul 7, 2013 | 09:47 AM
  #174
Moto260's Avatar
That's a cool trick. I didn't know that. Thanks. Ill try that out. And yea, that's possible i got the lines mixed up.I got an Evap canister code throwin at me too.
Old Jul 7, 2013 | 10:05 AM
  #175
Moto260's Avatar
Is there 6 injectors or just two?
Old Jul 7, 2013 | 12:20 PM
  #176
vital22re's Avatar
totally a bro
Pull all 6 injectors and have them cleaned and flow tested so they all match. A reputable injector shop will tell you if they are shot or not before cleaning. I know the 96-97 injectors had problems.
Old Jul 7, 2013 | 02:33 PM
  #177
Moto260's Avatar
Thank you for the advice Vital22re. Ill do that.
Old Jul 8, 2013 | 06:19 PM
  #178
Moto260's Avatar
So I had a few wires hooked up in the wrong places. She's runnin on all 6 now. Taking it to the shop for exhaust welding tomorrow.
I AM ALL THAT IS MAN!!!!
Thanks for all the help guys. Ill deffinently return the favor to future swappers.
Couldn't have done it without all you guys.
Old Jul 15, 2013 | 07:41 AM
  #179
Nice! She quick!? notice a difference!?
Old Jul 15, 2013 | 10:09 AM
  #180
Moto260's Avatar
Yes I do. Pull up hills now. Not the best on low end but mid and top are extremely good. First time I could do 65 up a summit haha. Used to 3rd gear tacked out with the 20r or 22re's lmao Needs a little bit of tlc here and there but engine is running great. :-D. Well worth it. I'd do it again
