3 wire to 4 wire TPS swap
Old Mar 14, 2011 | 07:21 PM
Fernley1's Avatar
Getting ready to start my 3.4 swap. The TPS on my new engine has 3 wires, the plug on my harness has 4 wires.
The question is do I have to swap the throttle body, or can I just swap the TPS.
(From 452-35020 to 452-22080)
Old Mar 14, 2011 | 07:31 PM
95blackToy's Avatar
well look and see if there are 2 constant grounds, or 2 constant positives or two of anything. Maybe you can just splice 2 of the wires together. All i can say is try it out and see.
Old Mar 15, 2011 | 12:57 AM
dodahman's Avatar
I see what you are talking about. I have a similar situation. I am using two different T100 wiring diagrams for my donor, a 1995 and 1997. The '95 has the four wire and the '97 has three. The missing wire is the IDL according to the diagrams. Looks like a vapor pressure sensor was added for latter models and is located in the fuel tank. I don't quite understand the relationship currently except the sensor VC pin is connected to the wire #2 on the TPS which connects to VCC on the ECM. I have the 3 wire harness and TPS but my ECM has the IDL pin. Thanks for pointing this out, now I'm confused!
Old Mar 15, 2011 | 01:32 AM
vital22re's Avatar
totally a bro
find a matching tps and throttle body to the ecu. Thats my suggestion.
Old Mar 15, 2011 | 05:36 AM
dntsdad's Avatar
Old Mar 15, 2011 | 08:49 AM
Fernley1's Avatar
Thats what I am wondering about. Can I just swap the TPS or do I swap out the whole throttle body. The only difference I can find between the throttle bodys so far is the TPS. I took out my 3 wire TPS to see what there was to it, not much, just a tab that follows the throttle plate.
Old Mar 15, 2011 | 04:43 PM
dodahman's Avatar
vital22re, that is what I am thinking as well. Can anyone explain the difference in the TPS and what the IDL does and why Toyota made the switch loosing the IDL and what replaced it?
Old Mar 18, 2011 | 02:57 PM
Fernley1's Avatar
I got a 4 wire TPS today and tried to install it on the throttle body, dont fit right.
So no is the answer to my first question.
Does any body have a 4 wire TPS throttle body for sale, or trade for my 97 4runner throttle body?
smthwsn357
May 1, 2024 07:28 AM
icentropy
Sep 16, 2020 02:47 PM
Sleaker
Aug 26, 2020 06:03 AM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
steve miller
Oct 10, 2015 01:40 AM
