3.4 Swap- Oil pressure switch
Old Feb 11, 2010 | 01:17 PM
stihl460's Avatar
Hey guys I am new to the forums and am in need of a little help. I have a 89 Toyota pickup 4x4 with a 3.0 that has a burnt valve a picked up with a 3.4 with low mileage that needs to be swapped in. I have everything close to drop in I am just confused on which oil pressure gauge to use as I pulled a sr5 dash with a tach and gauges from an 89 with the v6 motor and sender missing. Should I just get a sender from an 89 from autozone and change the connector? Thanks for the help.
Old Feb 11, 2010 | 03:16 PM
skunkwhat's Avatar
that should work
Old Feb 11, 2010 | 04:28 PM
RobD's Avatar
Just make sure you get the oil pressure sending unit and not the oil pressure switch. If you use the switch with your gauge package, you'll likely fry the oil pressure gauge.
Old Feb 11, 2010 | 04:35 PM
allnmstkn313's Avatar
You want to use a 3.0 SR5 oil sender. The non SR5 switch will not work. If you use the 3.4 sender you will fry your dash gauge.
Don't forget to add your 10k resistor to the dash for the tach.
Old Feb 11, 2010 | 06:30 PM
stihl460's Avatar
Thanks for the help!
bigjstang
Jun 2, 2025 03:56 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
88yodabasket
Jul 13, 2015 01:32 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
skoti89
Jul 8, 2015 12:05 AM
