3.0 to 3.4 swap help
Old Sep 15, 2012 | 07:08 AM
  #101
dntsdad's Avatar
On mine the White/blue wire is the B+ feed. That has power? Also, there was a black/red wire (ign2) that powers the injectors, and the coils I believe. that has power as well? When cranking as well?
Old Sep 15, 2012 | 07:50 AM
  #102
Racer's Avatar
Yes those both have power. Not sure when cranking, I'll have to check that
Old Sep 15, 2012 | 08:10 AM
  #103
Racer's Avatar
The white/blue wire that's coming from the harnesss? I have the b+ wire going into the ecu terminal b+. That all that needs to be done right? Or is there wire from the harness that goes with them?
Old Sep 15, 2012 | 03:40 PM
  #104
Racer's Avatar
Well I have good compression in all cylinders. Took plugs out and cranked over, no fuel, no smell at all. I can hear my fuel pump!!! So my injectors are not letting fuel in! There must be a wire from the 01 taco ecu that's has to be hooked up that I havnt. Diving me nuts!! Been weeks on just wiring all day! Goin over and over!! I start college on 23! Have to have it going! Anyone have any ideas!? Asap please!
Old Sep 15, 2012 | 04:46 PM
  #105
Racer's Avatar
Well something definantly not hooked up, no spark either I don't believe. Every like 5th time I crank it, it makes a slight start noise with starting fluid. But never any other time. So no constant spark. I guests I'm over my head. Might just sit untill I can afford a shop to hook it up for me.
Old Sep 15, 2012 | 07:32 PM
  #106
Racer's Avatar
Could it be the cam or crankshaft sensors? I will replace them if it's the problem. Any way to check for sure? They show voltage
Old Sep 16, 2012 | 03:27 PM
  #107
Racer's Avatar
Ok I got it running only with starting fluid. But fires everytime with it. So its fuel for sure! I'm getting fuel to the injector tower, they are just not getting signal I don't believe. Any help!? Please!? So close! Sounds so good for those few seconds!
Old Sep 16, 2012 | 05:39 PM
  #108
bensyota's Avatar
I'm gonna say your not getting help because u dove into this head first apparently without doing nearly enough research. These guys have been overly generous so far as in supporting you and knowing this fact already. It sounds like your almost there after a few bugs are worked out but I think you already stated your problem. You got in over your head.
Old Sep 16, 2012 | 06:40 PM
  #109
Racer's Avatar
I'm replacing the crank sensor tomorrow. My wiring is fine. I re-checked too Many times. It's a sensor or something under the hood at this point.
Old Sep 16, 2012 | 07:40 PM
  #110
vasinvictor's Avatar
It's your wiring. Forget the sensors
  #111
I like you.
Old Sep 16, 2012 | 08:22 PM
  #112
Racer's Avatar
Should I really not bother with the sensors? Injectors not giving pulse, crank sensor is what sends it. I don't see any other way of wiring it.just the injectors not sending fuel.obviously getting spark.
Old Sep 16, 2012 | 09:28 PM
  #113
anthony1's Avatar
Are you sure you don't have the fuel lines reversed?
Old Sep 16, 2012 | 09:33 PM
  #114
Racer's Avatar
I have the line on the passenger side getting the fuel. If I hot wire the pump I can feel fuel going straight through the return line. No pressure possibly?
Old Sep 17, 2012 | 12:27 PM
  #115
QuickSilver74's Avatar
my bet is the power to the injectors is wired incorrectly
Old Sep 17, 2012 | 12:36 PM
  #116
Racer's Avatar
Ok ill check again but can almost swear its wired in right. Red white b+ and constant, and ign2 all power
Old Sep 17, 2012 | 04:04 PM
  #117
dntsdad's Avatar
There is no red/white wire that supplies power on a 3.4 that i have seen but I havent seen everything. Maybe this one is different than the ones that I have worked on. I have only been into the 97 models.
Honestly, I never thought that you would get this far based on the questions that you were asking, but I will admit that I was wrong. Keep at it and when you find it, you'll be amazed it was right under your nose and you looked at it 25 times.
Id say its a wiring issue as well. If it was me I would ohm out ALL OF THE WIRES again. CPS rarely go out but they do I guess. Do you know someone that you could swap with? Did you test it? Very eqasy to do:
INSPECTION
NOTICE:
”Cold” and ”Hot” in these sentences express the temperature
of the sensors themselves. ”Cold” is from −10°C
(14°F) to 50°C (122°F) and ”Hot is from 50°C (122°F) to
100°C (212°F).
INSPECT CRANKSHAFT POSITION SENSOR RESISTANCE
Using an ohmmeter, measure the resistance between terminals.
Resistance:
Cold: 1,630 − 2,740 Ω
Hot: 2,065 − 3,225 Ω
If the resistance is not as specified, replace the crankshaft position
sensor.
Old Sep 19, 2012 | 06:41 PM
  #118
Racer's Avatar
Ok well thanks, been working on it constantly and trying to figure it out since last post. The crankshaft sensor is fine.
Old Sep 19, 2012 | 08:08 PM
  #119
Racer's Avatar
Is the data link connect
Old Sep 19, 2012 | 08:10 PM
  #120
Racer's Avatar
Is the data link connecter 3 the actually OBDII port? I am going to try and hook that up and see what codes I get.
