Upper balljoint replacement
Old Dec 7, 2003 | 09:18 AM
data's Avatar
Senior Member
Has anyone replaced an upper balljoint on the 3rd Gen? I found mine today leaking like crazy. Got a writeup?:pat:
Old Dec 7, 2003 | 04:31 PM
Bighead's Avatar
Danny, is your balljoint fried or is it just the boot leaking? If only the boot is leaking then you may just need to replace that and re-pack with grease. My local Toyota dealership tried to tell me that I could only order a complete new balljoint instead of just the boot. Steve Schaefer told me about the boot part number at CO4RJ.
Upper Ball Joint Boot: 43324-39015
Maybe it will save you a few bucks.
Old Dec 7, 2003 | 06:29 PM
data's Avatar
Senior Member
I believe the boot may just be busted. It does make a loud squeak though when I hit bumps, ect. Do you think I should replace the whole thing or just the boot? How difficult was just the boot to replace?
Thanks
Old Dec 8, 2003 | 02:36 AM
Bighead's Avatar
Every once in a while I have a loud squeak when I hit bumps. I found that came from my upper control arm bushings. A few squirts of WD-40 and it goes away for a couple of months. Maybe the squeak is something minor like that.
My ball joint wasn't bad after all. The boot did not seat properly when I swapped to the ATS arms so there was a slight leak. There was a test that somebody posted describing how to check if your BJ was bad. You might try and search for that. I can't tell you what all is involved in totally removing the ball joint since I haven't had to do it myself.
Old Dec 10, 2003 | 09:53 AM
Mohamed's Avatar
From what I have seen so far, ball joints are easy to take out and put in, so as long as you have a jaw puller tool. If the tie rod end is connected to the ball joint, after replacement, get an alignment as sometimes "toe" may vary with a newer joint.
Old Dec 10, 2003 | 05:33 PM
yotafool's Avatar
my ball joint boots are kinda busted from putting a knuckle adapter on my spindle with my lift, i have a 2nd gen, but you are saying that i can just get new boots instead of whole new assemblies, do they have them for 2nd gens?
Old Dec 16, 2003 | 02:16 PM
keisur's Avatar
haven't you been to my site Data?
http://www.keisur.com/upperbjrnr.htm
Old Dec 31, 2003 | 05:12 PM
BruceTS's Avatar
I found this on the net, it's a very simple tool you can fabricate to remove and install new upper ball joints....
I made a similar tool when I installed my Total chaos long travel kit.
Old Feb 26, 2005 | 07:55 PM
amorphous's Avatar
--->hey J - (i know this is an OLD post...) linky no worky! - I'm going to be needing to do mine sometime soon.....
a
lledwod
Aug 30, 2016 01:03 PM
Sep 4, 2015 09:27 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
HaydenConQueso
Jul 12, 2015 05:22 PM
akaphilly
Jul 9, 2015 02:27 PM
