Too much tranny fluid a problem?
Old Jun 2, 2005 | 11:04 AM
Del's Avatar
Del
This morning I checked my tranny fluid since I've been leaking fluids from just about everywhere possible, and it was a little low. It probably only could have used half a quart (in hindsight), but I put 1 quart in. I dont want to waste a thread for something like this but I can't afford to damage anything else as I've broken enough already
Do I need to drain any or will she be ok?
Thanks!
-Daniel
Old Jun 2, 2005 | 03:54 PM
CynicX's Avatar
not sure how much .5 quart is in the 3.0 tranny but just check the dipstick.....there are usually ranges "Cold I I Hot I I" if it is over then I would just crank the drain a little and try to measure .5 quart out. Its kinda a pain but its worth it to be on the safe side...
Usually overfilling results in fluid being aerating the fluid which isnt good for its lubercating effect, increased heat, foaming and it will come out of the vent. Draining it you will only get about 2 quarts out or so...I'm talking about an automatic btw....Only manuals I owned you filled them till they overflowed through the fill so I'm assuming your talking about an auto....
Old Jun 3, 2005 | 07:35 AM
Del's Avatar
Del
Thanks CynicX! Sorry I didn't specify, yes it's an auto.
the1998sr5
Jul 16, 2015 06:20 AM
Iceman4193
Jul 15, 2015 04:48 PM
Poncho0206
Jul 10, 2015 06:21 PM
madxman21
Jul 9, 2015 10:26 AM
Jnkml
Jul 6, 2015 01:20 PM
