Suggestions for re-occurring leaking injector
Old Jun 25, 2005 | 06:02 PM
dusty98's Avatar
On my 3.0 I have leaking injector that refuses to seal. I installed new o-rings, new washers, & new rubber seats on all 3 injectors on that side.
This helped for a few days, and then it re-occurred. I replaced the same parts again on this injector, sprayed all the grime away from the seat, cleaned the fuel rail with alcohol and q-tip. Put it back together and it was fine for a few days and it's leaking again.
This is leaking from the top, like it's not sealed. When I install the injectors, I put gas on the o-rings and make sure the injectors rotate freely in the fuel rail.
Any suggestions are appreciated.
Thanks,
Phil
Old Jun 25, 2005 | 11:20 PM
Maybe instead of gas on the oring, put some sort of lubricant. Who knows might not be seating all the way.
Old Jun 25, 2005 | 11:46 PM
DudeBud's Avatar
yes soak them in a lube. I use a teflon lube called engage but wd-40 or any other like it should work fine. good luck
Old Jun 26, 2005 | 03:23 AM
94x4's Avatar
Guest
Ditto the other similar responses. I, too, always use a lubicant... oh, wait, thinking of something else.
Seriously though, I've always used high temp silicone on my injector seating/sealing rings for durability and seal.
Old Jun 26, 2005 | 03:27 PM
dusty98's Avatar
I have both silicone spray lubricant and silicone sealer around. Once it quits raining around here, I'll give those a try. By the time I'm done, I'll be an expert at fuel injector removal
Thanks everyone!!
Eggslinger
Jun 8, 2019 03:32 PM
raptor510
Feb 17, 2017 07:11 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
HookahRoo
Jul 20, 2015 07:06 PM
karbin
Jul 5, 2015 11:37 PM
