Starting issues? HELP!
Old Jun 3, 2005 | 07:46 AM
Kcannaday's Avatar
Okay, I have a 99 4runner and I just installed a red top optima. Now at random when I try to start it up the first time I turn the key nothing happens, the warning lights come on at the bottom of the dash but it won't turn over or anything. The second time I turn the key it starts up like normal. What is going on, could the extra juice from the optima be messing with my starter somehow.
Thanks for any help!
Old Jun 3, 2005 | 10:45 AM
4Crawler's Avatar
Double check the battery cable connections. One may have loosened up since you installed it and is causing the problem. Try wire brushing the connectors and battery terminals to get a clean surface. I usually add a film of the silver colored anti-sieze compound to mine, keeps if from corroding and the metal powder in the compound conducts well. If that does not help, see the page below for some more troubleshooting ideas:
http://www.4crawler.com/4x4/CheapTricks/Starter.shtml
Old Jun 3, 2005 | 10:46 AM
LittleRedToyota's Avatar
4crawler has some good starter troubleshooting tips on his website...might help.
here is a link
Old Jun 6, 2005 | 02:13 PM
No Mechanic's Avatar
So could the starter possibly be the same problem if the battery is fairly new??
Old Jun 6, 2005 | 02:22 PM
4Crawler's Avatar
If the problem is in the starter/solenoid or in the wiring connected to it, you could have 100 new batteries hooked up and it would still act up. Find out where the trouble is, using the troubleshooting steps on the web page above, then fix it and it should work fine.
Old Jun 7, 2005 | 02:17 PM
I just had to replace my starter. it would start ever so often , I changed the battery also but in the end it was the starter. good luck
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Regency
20
Jan 3, 2020 07:43 PM
coryc85
Sep 9, 2015 06:24 AM
Avenged
Jul 9, 2015 07:55 AM
