Rebuilding 22re
Old Jun 14, 2005 | 07:26 PM
yota7's Avatar
Rebuilding 22re
hey guys, i have a 92 toyota truck 4x4. has 228,850 on the 22re and i want to re-build it. what kind of kits are out there? also i want to get more power out of it because i am going to bigger tires, so can i get better cams and all that good stuff too? what are you guys runnin in your engines?
bryan
Old Jun 14, 2005 | 07:35 PM
waskillywabbit's Avatar
www.pirate4x4.com
enginebuilder
lce engineering
to name a few...
local dealership...
Old Jun 14, 2005 | 08:32 PM
kyle_22r's Avatar
www.engnbldr.com for your master kit. not a bad kit at all for the price. if you want to get expensive, you could always get parts from LC engineering.
these are easy engines to rebuild, the main part is making sure the block and head are true, flat and clean before putting on the head gasket, and to use a good gasket(engnbldr's is a good quality one). i learned the hard way(broke my cam, so i pulled the head and also did the gasket and used a cheapie, now 2000 miles after that and my truck is sitting in the driveway with no head!)
Old Jun 14, 2005 | 09:13 PM
jimbo74's Avatar
a friend of mine just bought an lce motor.... already tweaked out... has about 135 hp.. will be 160 when hes done doing his intake, ehuast, all that stuff
Old Jun 16, 2005 | 06:12 PM
yota7's Avatar
how much did he pay to have the lce done? i have been looking on the engnbldr.com and that master kit really looks like a good deal. also another question, what can i do to my exhuast to make it a bit louder and give it a little deaper sound? since it is a 4 cyl, i didnt think that there was much of anything to get it to sound that great? is the flowmaster 40 series any good on these?
bryan
Old Jun 16, 2005 | 10:37 PM
Toyrantula's Avatar
3 grand for a complete rebuild.
The head was a tad over $500 for all new valves and guides, plus the machining and Crane Cam.
The block got new bearings, rod resize, 30 over pistons and rings, machining.
Includes used timing chain cover, new timing chain, oil pump, new clutch and gasket set. Had the air plenum hot tanked to remove the black sludge.
Assembled back into a long block. Pricing is Canadian.
bigjstang
Jun 2, 2025 03:56 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
coleypull15
Nov 3, 2015 07:41 AM
shisha1999
Sep 21, 2015 08:22 PM
shadowbirdie
Jul 21, 2015 10:38 PM
