ps pump belt install issues
Old May 4, 2005 | 08:01 PM
fatdudesurfin's Avatar
i'm currently wrapping up a timing belt/water pump job on my 92 3vze, but ran into a possible problem when reinstalling the ps pump belt
the belt, when set on the pulleys, and all pulleys torqued down, does not appear to run in parallel on all the pulleys. basically, it looks a bit like this:
top down view
..| <- belt on crankshaft pulleys (one on top and bottom)
./ <- belt path in between crankshaft pulleys and ps pump pulley
| <- belt on ps pump pulley
the belt seems to travel on different planes, about 1/8" apart. i dont know wether this is expected, wether theres some washer im missing, or wether there is a problem when i installed my pump. the belt doesnt travel in a single plane right now, whats the deal with it?
Old May 4, 2005 | 08:24 PM
amorphous's Avatar
Well, if it was correct when you took it off, then you forgot a spacer or something. Did you have any leftover parts???
Old May 4, 2005 | 08:26 PM
dont have any left over parts
FSM doesnt show any washers of any sort spacing the pulley from the pump
it just seems incorrect to me, and id like to hear from some mechanics with more experience on the 3vz
Old May 4, 2005 | 08:29 PM
amorphous's Avatar
wowza. got me stumped. I'm doing belts this weekend....i'll be careful!
btw, i'm doing belts on a 3.4l, so I'm no help....
a
Old May 4, 2005 | 08:32 PM
good luck w/ that man. hopefully your engine isnt a single rusted block like mine is
Old May 5, 2005 | 06:35 PM
anyone have any ideas? im not sure where to go from here
Old May 6, 2005 | 07:25 AM
eric-the-red's Avatar
All I can think of is check you put the pulleys on the right way. It's been a while since I did my timing belt but I seem to remember some of the pulleys have a front and a back, ie the groove is not centered.
You'll definitely want to correct it before driving much, the belt won't last long like that.
Old May 7, 2005 | 07:46 PM
Mad Chemist's Avatar
Sounds like you might have the pully on backwards, probably has a "backspacing" on it that doesn't allow you to re-install it either way. Look for a spacer/washer that you might have missed as well.
Old May 9, 2005 | 05:37 PM
not sure what the problem ever was, but i ended up making a spacer out of a washer by grinding out a slot for the locking pin. belt sits level with engine now
thanks for the help
bigjstang
Jun 2, 2025 03:56 PM
icentropy
Sep 16, 2020 02:47 PM
coryc85
Sep 9, 2015 06:24 AM
nick b
Jul 11, 2015 04:38 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
