Power Window Squeal
Old Oct 8, 2002 | 07:29 AM
HBoss's Avatar
Power Window Squeal
This sound is driving me nuts & only comes out when it's cold. It only occurs with the front windows when it's nearing or below 0 degrees Celcius.
It's a high-pitched squeal that makes you cringe. It sounds like chalk on chalkboard. I've siliconed the rubber surrounds and taken the door panel apart to oil the slides and hinges. I've looked for grooves on the windows indicating something (like metal) is scratching it, but no spectacular find there.
Other than constantly siliconing both windows & power window parts, does anyone have any suggestions? Thx.
Al
Old Oct 8, 2002 | 09:21 AM
Juppers's Avatar
I had a similar problem with one of my old vehicles. I found using lithium grease as the lubricant worked much better than any other lubricant I had tried to rid myself of the cold window squeak. You can pick up a spray can for a few bucks at any auto parts store.
Old Oct 8, 2002 | 09:44 AM
HBoss's Avatar
Thx Juppers. I'll see if I can try some of that instead of silicon...time to take the door panels off again...fun fun fun
Al
Jun 1, 2021 01:51 PM
westonian18
May 1, 2020 06:38 AM
okamikai
Apr 30, 2018 10:19 PM
coreyedwards7611
Jan 16, 2016 06:38 PM
Johntom240
7
Jul 13, 2015 12:18 AM
