Pinion Seal leaking?
Old Jun 27, 2005 | 03:33 PM
Silver_Truck's Avatar
I've got a leak coming from somewhere on my rear end...I think it might be leaking out of a pinion seal as its leaking onto my driveshaft and throwing gear oil everywhere on the underside of my truck. Is that what is leaking or what else could it be? Thanks guys
Old Jun 27, 2005 | 03:35 PM
seaflea's Avatar
Is it coming from the axle area or the transmission area? I will assume the axle, in which case it probably is the pinion seal.
Old Jun 27, 2005 | 03:39 PM
its coming from the front of the rear diff
Old Jun 27, 2005 | 04:04 PM
jimbo74's Avatar
most likely the pinion seal due to a bad breather.... i replaced my diff breather and extended it per the writeup at www.4crawler.com and it has not leaked since....
Old Jun 27, 2005 | 04:07 PM
DudeBud's Avatar
pinion seal easy fix. if memory serves me right it takes a 32mm socket. a 1/2" impact gun sould zip the nut right off. if you dont have one then you could try pulling the ebrake and then trying the nut. its tight some where around 200 foot pounds.
Old Jun 29, 2005 | 07:05 AM
4Crawler's Avatar
30mm socket. You need to unstake the nut, and take note of where it was tightened down to so you can replace it to the same position to avoid changing the pre-load on the pinion bearings. Restake the nut after putting it all back together.
Old Jun 29, 2005 | 09:01 AM
Robinhood150's Avatar
Or about $50 at a good gear shop.
jasonty
41
Dec 23, 2018 01:00 PM
yourrealdad
Jul 29, 2015 11:08 AM
Iceman4193
Jul 15, 2015 04:48 PM
andrewtexas123
Jul 14, 2015 04:29 AM
jakebarrett
Jul 10, 2015 07:15 PM
