pcv valve ?
Old 09-15-2003, 04:58 PM
bugalu's Avatar
pcv valve ?
OK stupid question, where the heck is the pcv valve on a 95 4runner with 3.0L V-6. I can't find the thing. truck is using a little bit of oil and would like to rule out the pcv valve.
bugalu is offline
Old 09-15-2003, 05:18 PM
AverysDad's Avatar
if you look at the passenger side valve cover under all those hoses you should see a rubber hose connected directly to the vavle cover itself. if you take off that hose you should see the pcv valve.
p.s. i tried to find a pic for you but couldn't locate one....sorry
AverysDad is offline
Old 09-16-2003, 05:37 PM
bugalu's Avatar
Thanks, I was afraid it was on that side. Now, the trick is how to reach it. I'll look into it more on my day off, Thanks again
bugalu is offline
LotOMiles
09-14-2015 11:45 PM
ac7822
09-11-2015 08:49 AM
Boomer8404
09-10-2015 09:01 AM
idadan208
09-07-2015 09:06 AM
Quick Reply: pcv valve ?
