pcv valve ?
OK stupid question, where the heck is the pcv valve on a 95 4runner with 3.0L V-6. I can't find the thing. truck is using a little bit of oil and would like to rule out the pcv valve.
if you look at the passenger side valve cover under all those hoses you should see a rubber hose connected directly to the vavle cover itself. if you take off that hose you should see the pcv valve.
p.s. i tried to find a pic for you but couldn't locate one....sorry |
Thanks, I was afraid it was on that side. Now, the trick is how to reach it. I'll look into it more on my day off, Thanks again
