pcv valve ?
Old Sep 15, 2003 | 04:58 PM
bugalu's Avatar
pcv valve ?
OK stupid question, where the heck is the pcv valve on a 95 4runner with 3.0L V-6. I can't find the thing. truck is using a little bit of oil and would like to rule out the pcv valve.
Old Sep 15, 2003 | 05:18 PM
AverysDad's Avatar
if you look at the passenger side valve cover under all those hoses you should see a rubber hose connected directly to the vavle cover itself. if you take off that hose you should see the pcv valve.
p.s. i tried to find a pic for you but couldn't locate one....sorry
Old Sep 16, 2003 | 05:37 PM
bugalu's Avatar
Thanks, I was afraid it was on that side. Now, the trick is how to reach it. I'll look into it more on my day off, Thanks again
LotOMiles
Sep 14, 2015 11:45 PM
ac7822
Sep 11, 2015 08:49 AM
Boomer8404
Sep 10, 2015 09:01 AM
idadan208
Sep 7, 2015 09:06 AM
