Need fuel filter R&R advice for my 96
1996 4Runner SR5 3.4L V6...
Ok guys, I am gonna tackle my fuel filter. It looks pretty easy. I know where it is, and I have done them on other vehicles in the past.
A few questions that my search did not answer:
1. Does anyone know of a write-up on this?
2. How do I relieve the fuel pressure on the 5VZ?
3. Anything else I should know before I do it?
Thank you for the replies in advance!
I used a "crow foot" to get the nuts on the filter off.
-Try spraying the nuts with PB Blaster or something to get it loose.
-Its going to be hard to get it loose, but be careful not to put too much force into it or you may twist your fuel line.
-I think you can relieve the fuel pressure by pulling the fuse and cranking the engine a few times.
-Buy a TOYOTA filter (but you probably already knew that!)
I thought just to relieve the ful pressure you just open the gas cap? and the hissing noise is the pressure going away? Remember reading that a looong time ago over a 4x4wire.
Anywho, Christian you know what you gots to do when you finish this right? Yep yep it's time for a write-up! so then I can do mine over here
Its a foot of a crow, of course!!
J/K I am just messing with you.
click here
It helped me get an angle and leverage that I couldnt' get with a piping wrench or a combo wrench...
click here
Yeah, I will do a write-up. I need to get my butt in gear if I want to catch Bob anytime soon.
On most Nissan's you pull the EFI fuse and crank the motor over to relieve the fuel press. On Honda's you loosen a banjo bolt. Now for Toyota's...
The fuel pressure in the line needs to be relieved at the fuel rail or by running the fuel in it out. I am not sure if Toyota's have a place to relieve the pressure on the rail, I know that Ford's do (it looks like a tire valve stem).
I used a flare nut wrench and a regular wrench when I did mine. Flare nut wrench on theoutside to do the turning, and a regular (or adjustable) wrench on the inside to keep things steady and prevent twisting.
Click here to see what a flare nut wrench looks like.
A crow foot is basically just the head of the wrench.
I just vented the gas cap to relieve pressure on the lines. You could also pull the fuse to the fuel pump, and then run it till it stalls, but I didn't think it would really be necessary. If you don't run it dry, then you will have a little gas run out, so just have rags or something handy.....and keep the drag light clear of there!
Flex head. Mine isn't a Snap-on though , its a Mac.
should i ?
hey all,
should i attempt this myself ? or pay the dealer ? i dont have much in tools, i have more time than anything, but the dealer wants $100 im thinking about letting them do it, this way i know its done right, if not, they get to fix anything thats not,
Ric
Ric
I think you should at least wait for Christian's write-up. He's usually really descriptive. And depending on his write-up, I might try to do this myself. And if I do this myself......You best be able to do it cuz I have no skillz whatsoever!!!
ok
well i was thinking that id atleast wait untill the oil change, so it gives me about a month..
Shoot, I only have a month to do the write-up? I better get going!
By the way Todd (TOR) can get these for $33 shipped. That is most likely where I will get mine.
pyramid
Jul 30, 2015 10:05 AM
