how do i remove stripes
Old Oct 8, 2003 | 07:27 AM
Guys ive got a 94 truck with the big sticker on each side. Over the years is has starte to flake and peal. I have deciced to take all the way off. Just wondering what you all used to do it.
thanks
Shawn
Old Oct 8, 2003 | 07:29 AM
jacksonpt's Avatar
Senior Member
Wait for a really hot day and take a hair dryer to it. The goal is to heat up the adhesive that holds the sticker one. If you can do that, it should peel of fairly easily. Then use something fairly abrasive (Meguiars Scratch X, rubbing compounds, etc.) to get the left over adhesive/residue off. Then give it a good waxing to protect the paint you just exposed.
Old Oct 8, 2003 | 10:17 AM
hey thanks, i just want to get the stickers off.. dont need to worry about the pait, there is no help for it at this point.
Old Oct 8, 2003 | 11:07 AM
runningman's Avatar
dr
or just use a solvent to wipe them off. (the adhesive i mean)
Old Oct 8, 2003 | 11:09 AM
rimpainter.com's Avatar
I hosed the graphics on my old Tacoma with Bug and Tar remover, then used a hairdryer like the other guys said. Didnt take me that long considering it was 110 that day.
Old Oct 8, 2003 | 11:20 AM
thanks guys, im going to get a scraper and the hair dryer out when i get home.... see if can get them off..
They didnt bother me that bad till they started to fade so they go from gray and black to light gray and dark gray to white as the stripe goes down the side.
Old Oct 8, 2003 | 11:28 AM
mtnfreak's Avatar
As usual, Roger has what you need - HERE
Old Oct 8, 2003 | 01:15 PM
tkrispin's Avatar
I second the use of bug and tar remover, I got a whole bottle of it and after peeling back the stripes (just used a hot sunny day) I removed the adhesive with a cloth and lots of elbow grease. Got a few blisters along the way.
Old Oct 12, 2003 | 07:08 PM
Plays_with_Toys's Avatar
I need to do this soon as well... So with the bug and tar remover, it will disintegrate the sticker or what?
My truck's stickers are BAKED on there. The previous owner didn't do anything to protect it from the sun. I am not worried about the paint either , because it will be resprayed a few days afterward. So what about sanding them off? Or is the bug and tar still easier? Thanks!
And sorry to jack the thread, but I was going to ask this question anyway, so might as well put it here.
Old Oct 13, 2003 | 05:08 AM
They came off easy but the stickey part (glue).
What i did was take a hair dryer and get the end of the sticker hot, then slowley start to peel it off. I also kept moving the hair dryer further down the sticker as i pulled it.
It took me about a hour per side but my stickers where ripped and cracke and chunckes missing so it had to keep starting the process over.
As for the bug and tar remover its used to get the glue off. I also found that alcohol does the same and its like $5.00 cheaper I had to use my fingernail to scrape with so a plastic razer blade would be usefull.
1uzRunner
63
Nov 10, 2018 03:58 PM
choppe777
May 16, 2016 08:00 AM
Anthony Lee Mathis
Sep 15, 2015 07:22 AM
gp66
Sep 7, 2015 08:29 AM
Aaron Logan
Sep 3, 2015 08:08 AM
