Help!!!!!
Old Jun 17, 2004 | 04:50 PM
87 4runner's Avatar
Unhappy Help!!!!!
ok the oil temp, charge and brake lights are on in my truck ... theyall just came on..... and sometimes they go away for a second when i drop it into drive but they come back on .....this all happend after i left my keys in the ignition and the batt went dead and now that i have charged it i hvae this .... can anyone help me ....i dont think i have these problems but who knos
it is an 87 auto 22re
thanks,
derek
Old Jun 17, 2004 | 05:35 PM
keisur's Avatar
maybe you burnt up your ignition coil. was the key turned to "On" with all the gauge lights on when the battery got drained?
Old Jun 17, 2004 | 05:38 PM
96SR5's Avatar
This may not help but try to reset your ecu. If that don't work replace your batt and try once more. Just A thought.
Old Jun 22, 2004 | 12:54 PM
JoKEpLaYeR's Avatar
Did you do a deep cycle charge without unplugging the leads from the battery? Or did you leave your keys in the on position when you charged it?
Old Jun 22, 2004 | 01:20 PM
AgRunner06's Avatar
I'd say start checking fuses and then pull your efi fuse for 10 minutes to let your computer reset. That's the only thing I can think of.
Good Luck
Old Jun 22, 2004 | 04:17 PM
anthony1's Avatar
thanks,
derek
You might have a bad alternator. see if the lights went away when you rev it.
You can take it to Autozone and they'll check the charge for you.
Old Jun 22, 2004 | 06:47 PM
dusty98's Avatar
I'm not sure about the 22RE, but in my 3.0 when the charge and brake light came on the alternator was about to go.
Since your battery was just drained, I'd check the battery connections & make sure they're clean & tight. Take a voltmeter to your battery; prior to starting should have around 12 volts, once the truck is running should see around 14 volts.
You also might want to have the battery checked & make sure none of the cells are dead.
Good luck!!!
Old Jun 23, 2004 | 07:50 PM
87 4runner's Avatar
well it is fixed ..... happend to be a hillbilly riged fog light wire from the previous owner
