getting hot at 65
Old May 7, 2005 | 08:31 PM
Lukeman82's Avatar
getting hot at 65
it was doing good there for awhile. rebuilt engine, vacuum troubles had been taken care of, got a new pair of shoes, all seemed very well..... then at speeds above 65 it decides to rapidly gain temprature. so far i have changed the thermostat, removed the radiator and flushed it out, replaced the upper radiator hose, took the water pump driven fan off and shoved in an electric one, checked the temp probe in the intake manifold. timing is right where it needs to be but have played with it to see if it makes a difference, it doesn't. the coolant even flows the right way so i don't think i got a backwards impeller on the water pump (it's happened to my dad and he told me to check)
anybody have any thoughts, tips, tricks or whatever to possibly help me in my heated state?
Old May 17, 2005 | 06:40 PM
Lukeman82's Avatar
Question
nobody has any ideas as to why my truck is running hot at 65?
Old May 17, 2005 | 06:53 PM
rimpainter.com's Avatar
Does your heater work (get hot)?
Old May 17, 2005 | 07:34 PM
Yota4runner's Avatar
Have you done a pressure test on the system yet?
Old May 18, 2005 | 07:31 AM
4Crawler's Avatar
My '85 did the same, turned out to be a partially cloged radiator. Look inside the filler on yours and have a look at the cooling passages. If there is buildup inside, consider having the core rodded at a shop or just pop for a new 3-row radiator.
Old May 18, 2005 | 07:35 AM
X-AWDriver's Avatar
I thought this thread was going to be about a geriatric fixation.
dbollier123
Sep 29, 2015 05:23 PM
Matthew Perez
Sep 28, 2015 05:43 PM
taraf
Sep 25, 2015 02:57 PM
LotOMiles
Sep 14, 2015 11:45 PM
anndel
Sep 10, 2015 08:50 AM
