Fuel Filter
Old May 10, 2005 | 03:57 PM
Lone4runner's Avatar
Fuel Filter
Hopw bad is it to change a fuel filter? i was going to have a dealer do it but they warned me not to cause once i get the filter off i may not be able to get it back on without replaceing the whole assemble. they stated it gets rusted bad enough where it wont fit back. any input on anybody whos changed their fuel filter on a 3rd gen 4runner?
Old May 10, 2005 | 04:08 PM
ScottyBean's Avatar
funny you ask, i have a 96 4runner. no more than 10 minutes ago i took the fuel filter off, dumped it and shaked it dry(my version of cleaning it) and put it back on. NO problems. some fuel came out but it stops.
Old May 10, 2005 | 04:28 PM
lol so it was just that easy. sounds good to me
Old May 10, 2005 | 05:01 PM
jimbo74's Avatar
yuo think its unclogged jsut because you shook it dry? LOL!!!
Old May 10, 2005 | 06:07 PM
Tacoma Dude's Avatar
Scotty:
A replacement filter doesn't cost that much. You may just want to get a new filter. I'd say it's analagous to taking out the oil filter, shaking it a few times, and putting it back in
Lone:
You have a 3rd gen? I don't know how bad things get in the rustbelt (if you're anywhere around there) but I was able to change it on my 1st gen (i.e. 1986) with little problems just a few months ago.
Of course, as with all things, your experience may vary.
Old May 10, 2005 | 06:23 PM
4RUNR's Avatar
Guest
Yes, the fuel lines, the filter, and the fittings that go into the fuel filter are steel, thus rust. In Massachusetts you will likely need to wire brush the fittings if you want a good seal again, so you'll need a comfortable spot with good lighting, i.e. a garage.
Take a picture of the fittings, they are plainly visible behind the frame rail under the driver seat.
Old May 10, 2005 | 07:17 PM
so as far as your concered this will not be an easy thing for me to do then ? cause i have no garage nor a comfotable spot lol. part is cheap just didnt know if me doing it was better or just allowing a staelership to take it
Old May 10, 2005 | 07:53 PM
4RUNR's Avatar
Guest
“Not easy” is very relative, but yes, it’s going to be more difficult than changing the engine air filter. Not much skill is required to brush off the rust, but you would need to get under there and see what you are doing quiet well.
smthwsn357
May 1, 2024 07:28 AM
Eggslinger
Jun 8, 2019 03:32 PM
pyramid
Jul 30, 2015 10:05 AM
ddg71
Jul 24, 2015 01:24 PM
Fundy Rider
Jul 16, 2015 01:35 AM
