Friend's 97 4Runner did not pass emissions test (Nitrogen Oxide) -- what's the cause?
Old Aug 4, 2004 | 08:48 PM
Bob_98SR5's Avatar
My friend's 97 4Runner did not pass emissions. They said the NO level too high (Nitrogen Oxide).
What would cause it to be too high?
Bob
Old Aug 4, 2004 | 09:09 PM
shazaam's Avatar
NO bottle in the trunk
Old Aug 4, 2004 | 11:44 PM
Tacoma Dude's Avatar
Sounds like maybe something with the catalytic converter - I JUST read up on this today too!
Towards the middle of the page is what you'll find interesting:
http://auto.howstuffworks.com/catalytic-converter2.htm
Old Aug 5, 2004 | 07:43 AM
eric-the-red's Avatar
high NO often is from EGR not working properly, that's the first place I would start.
Old Aug 5, 2004 | 08:01 AM
Bob_98SR5's Avatar
eric and pete,
ok, thanks. ill read up and check out the EGR valve.
bob
Old Aug 6, 2004 | 11:02 AM
Bob_98SR5's Avatar
Ok guys,
I have his test results. Yellow box shows his NO was too high. Can anyone who knows interpret this? His CO is fine but the NO is too high---is this a more definitive sign that the EGR valve needs replacing?
Bob
Old Aug 11, 2004 | 08:34 PM
BruceTS's Avatar
Most cases it's the cat that has gone bad, most likely the EGR valve is fine, it would have came up in the inital inspection.
Old Aug 11, 2004 | 09:07 PM
Bob_98SR5's Avatar
hey bruce,
the dealership and the parts guy i buy from both say there is no egr valve on the 3rd gen 4runners.
they suspect it might be the cat too, but they both recommended that i change out the plugs and wires, clean out the fuel injection system w/ BG44K, and change the pcv valve. don't know what that might really do but he needs to do this anyways.
bob
Old Aug 12, 2004 | 02:17 PM
Oscar's Avatar
I just got emissions tested today. I've got the same issue.
The technicians gave me a document describing possible causes for failing the NOx test.
1) Inoperative/ineffective Exhaust Gas Recirculation System
2) Excessively lean AFR
3) O2 sensor malfunction
4) Engine deposites
5) Malfunctioning or missing catalytic converter (3-way catalyst only).
Did your figure the problem out yet?
Old Aug 12, 2004 | 02:27 PM
Bob_98SR5's Avatar
Oscar,
We're still waiting for the parts to come in. We're going to install them and do some other maintenance work before re-testing.
I have a sinking feeling that it might be the cat.
Bob
Old Aug 27, 2004 | 12:30 PM
Bob_98SR5's Avatar
Guys,
Just a follow up to this story: I replaced the front 02 sensor for him yesterday and he passed his smog test this morning.
http://www.4runners.org/articles/02sensor
Thanks for all the help and advice, guys!
Bob
Old Aug 30, 2004 | 12:31 PM
payyourtoll's Avatar
and a write-up to boot
Old Aug 31, 2004 | 10:57 AM
Hello all,
I just got myself failed this weekend as well. My NO2 was around 760 with 15mph. The smog technician recommend me to do an PCV replacement and clean out the fuel injection, do a test drive and retest. Guess what? NO2 now is only 300. Just want to share.
Old Sep 7, 2004 | 05:33 PM
emotepix's Avatar
Mine too. NOS 1080 over a CA permitted 330. Bummer...
Old Sep 7, 2004 | 08:17 PM
Bob_98SR5's Avatar
pepsi,
we changed:
- pcv
- fuel filter
- front 02 sensor
the first two had no effect on the NO2 reading (failed). when we changed the front 02 sensor, everything was oooootay!
bob
Old Sep 7, 2004 | 08:22 PM
Bob,
Was there a reason why just the front O2?
Old Sep 7, 2004 | 08:39 PM
Bob_98SR5's Avatar
Originally Posted by Tacoma Dude
Bob,
pete,
thats what the diagnostic report said.
bob
Old Sep 7, 2004 | 08:41 PM
Ah okay
I wasn't sure if the front because it's most likely to fail or what.
Jun 1, 2021 01:51 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
timmJ
Jul 7, 2015 02:01 PM
cyclist231
Jul 7, 2015 12:56 PM
Jnkml
Jul 6, 2015 01:20 PM
