Engine shampoo ?
Well, everything does end up in the ocean.
I have a few surfer friends that will go surfing in the rain and come back with sore throats and other symptoms because of the nasty run-off.
Yeah, they don't learn.
Spray-9 works great but is hard to find. It is an awsome degreaser/cleaner. If Spray-9 cannot be found, Simple Green is the next best thing. Good luck.
Also so you can convince your wifes/girlfriends to let you buy gallons of it, Spray-9 is also nice to use in the house since it is also anti-microbial and anit-bacterial. Great for cleaning up in the kitchen and bathroom.
#25
Originally posted by Darx
Anyone ever had their engine steam cleaned? I saw somewhere that offered that service.
#27
Mean Green
I usually use a combination of Gunk and Mean Green (from the dollar store). I have found that Mean Green, the generic of Simple Green, actually works considerably better and it is cheaper. I usually pressure wash non electrical areas of my 3.0 after soaking it with those ingredients.
#28
If the engine isn't really greasy. I'll use ERA laundry soap mixed with a bit of steaming hot water. Use a spray bottle to spray it. Let it set for a few minutes. And rinse it off. I like this idea cause ERA won't harm paint, hoses, belts, etc. On the other hand, if the engine is really greasy. I use this citrus based cleaner called BIG ORANGE. I think ZEP makes that stuff. I just take it from work.
#29
i use purple power and gunk. purple power for the thick stuff around the engine bay and directly on the engine bay. usually put it on a cloth and wipe (or scrape) the dirt/grease away. gunk, i just spray and let it sit. spray with regular hose water. then wait till it dries a bit and use the gunk detailer to detail all the rubber/plastics so they'll be super shiny.
jasonty
41
Dec 23, 2018 01:00 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
