Engine shampoo ?
I would like to clean the engine .I have some simple green form a local shop .Is there anything better ?
Better get the dandruff control & make sure you scrub real good. Kiddin. I need to do this also but always forget to ask what works best. I will listen in.
I've always heard Simple Green is pretty good...but when I looked for it they had what was called an "All-Purpose Cleaner"...not just a degreaser or anything...I will be listening in as well.
Fink:devil: |
I had my simple green with me tonight and thought I was gonna wash my eng. but the frikkin car wash looks like an ice cavern. The walls and control dials were covered in ice. I kinda said uh forget that and will do it later. Who knows maybe there is a better product out there. I will keep listening. I bet Corey has some good eng. detailing tips for us. Corey?
I simply use Gunk Engine Foamy Brite.
It's in a spray can, and comes out like heavy suds. I spray it on and let it sit for a bit, then rince. I repeat it once more. There are some very excellent posts here on this if the database is fully restored. A lot use this stuff called CRT I think, which includes the cleaner, and a bottle of spray dressing you put back on afterwards. However the dressing may attract dirt more if you take it off road, I am not sure. Contact Jason B on that stuff, as he uses it and has before/after pictures of it. Here's my dirty engine bay from last year or so. http://www.toyotaoffroad.net/tando/e...ash/dirty1.jpg After using the Gunk stuff. http://www.toyotaoffroad.net/tando/e...ash/clean2.jpg |
WOW! That's a big improvement. Now I would be interested to hear somebody compare the two...Simple Green and Gunk to see which one is better. Corey, should that Gunk be at just a local auto supply store or did you have to order it? Thanks man.
Fink:devil: |
Any good Auto store that is worthy should carry it.
Which electrical components do I need to cover or look out for before cleaning the engine?
re
ive used oven cleaner in the past, just drove to the store to get it, then sprayed it one while its hot, let set for a few, then hosed it off, looked pretty good,
Did the engine compartement today .
As per the intructions I wet the engine. Sprayed the Simple Green on and left it for a few minutes .It rinsed off with out a problem. One thing that I have learned about shampooing engines is NEVER USE A PRESSURE WASHER . Most electical parts are covered from regular moisture and water .High pressure water will get passed these covers . |
I ran into turboale's site and saw his before and after pics of his engine after using Simple Green. I just had to try it after seeing the difference... well it worked great for me.
I didn't take pics of mine but here are pics from turboale's site... hope he doesn't mind: http://homepage.mac.com/turboale/images/EngineDirty.jpg http://homepage.mac.com/turboale/images/EngineClean.jpg http://homepage.mac.com/turboale/Engine.htm |
So judging by turboale's pics all you need to cover is the battery?
I'll go to the store and get some Simple Green or Gunk and see what I can do with it! Fink:devil: |
I would also cover the alarm horn (if you have one) it takes a few days for it to dry out if you get water inside and sound terrible during that time.
Mean Green
My wife turned me on to some stuff called "Mean Green" that you can buy at the Dollar store or Dollar General and it's super cheap. I was cleaning the grease form our grill on the patio and when i sprayed it on the grease just ran off like it was water. I was so amazed i trued on my muzzle loaders and it desolved the grease and pwder the same way. Then i sprayed the engine and let it sit for a bit, sprayed it off with a hose and the thing sparkled.
Try it sometime. You will be glad you did. Mike :D |
Gunk and most other engine cleaners have a petroleum base.
I have used them and they do clean well. And I do rinse very well. But your vehicle smells like kerosene for several days afterwards. |
Originally posted by humanoid Which electrical components do I need to cover or look out for before cleaning the engine? Originally posted by hatcoleman Gunk and most other engine cleaners have a petroleum base. I have used them and they do clean well. And I do rinse very well. But your vehicle smells like kerosene for several days afterwards. A round brush like the type you find for stenciling and a bunch of foam "q-tips" and you're set. Use low pressure on your hose. I would rather scrub for an hour than have to spray my engine a few times to clean it up. I think that just ups your chances of screwing something up. If you start with a slightly warm engine the grime will be easier to remove. That's what I do. -Stu. |
Originally posted by hungryStu If you look around in your engine and see any electrical component that is questionable, cover it and clean it via brush/damp terry towel and hand. Battery, alternator, alarm horn, horn, ECU, Mass Airflow Sensor, Fan Relays, fuse box, etc, etc. Foil works well as it conforms to the component. Petroleum-based engine cleaners are also really hard on belts, vacuum hoses and the like. If you are to use a petroleum-based cleaner (for ease of the procedure) I would suggest getting a very good rubber and vinyl dressing like 303 Aerospace Protectant and using it well. Citrus based cleaners like Eimann Fabriks Citrus Engine Degreaser are much easier on rubber, aluminum, the paint in your compartment and don't smell bad at all. A round brush like the type you find for stenciling and a bunch of foam "q-tips" and you're set. Use low pressure on your hose. I would rather scrub for an hour than have to spray my engine a few times to clean it up. I think that just ups your chances of screwing something up. If you start with a slightly warm engine the grime will be easier to remove. That's what I do. -Stu. |
I used simple green a little while ago.
I didn't cover up the battery or alternator but didn't spray them directly with the hose. No pressure though - just regular hose. Everything came out pretty clean :bigok: I did make it a point to start the engine right after I was done and take a spin around the block to make sure it all worked fine ;) |
Also you need to be careful, some states/towns have out lawed the use of some of this stuff. If you live next to a busy body neighbor check before you start. But I have used Gunk, it works great, but I think it is now illegal in California.
My two cts... |
Originally posted by funglenn Also you need to be careful, some states/towns have out lawed the use of some of this stuff. If you live next to a busy body neighbor check before you start. But I have used Gunk, it works great, but I think it is now illegal in California. My two cts... |
