Depressurizing the fuel system?
Old Jul 2, 2004 | 04:45 AM
Back40's Avatar
Getting ready to change my fuel filter (92 4x4 xtra cab 3.0 V6) but my Haynes manual does not provide the specifics of how to depressurize the fuel system prior to loosening the banjo bolts on the filter. Your advice is much appreciated.
Old Jul 2, 2004 | 05:02 AM
TDiddy's Avatar
1. Remove the gas cap. This will help but won't depressurize fully.
2. Pull the fuel pump relay and run the motor till it dies. This will pretty much empty out the fuel line.
Old Jul 2, 2004 | 07:28 PM
Maddog's Avatar
I just undid the cap for a few seconds,I only had about 80ml or so fuel leakage.
Old Jul 2, 2004 | 07:42 PM
ChickenLover's Avatar
Originally Posted by Maddog
80ml
Ahhhh come on. Put it in terms we can understand. How much of a beer can is that? J/K
Old Jul 2, 2004 | 07:44 PM
I just did a write up on the 2nd gen fuel filter. Go give er' a read. It was fairly easy with some help from my good friend pb-blaster. I tried to explain everything in detail.
Old Jul 4, 2004 | 12:07 PM
Back40's Avatar
My Haynes manual does not illustrate the location of the fuel pump relay. Can someone point me in the right direction?
Old Jul 4, 2004 | 12:09 PM
Back40's Avatar
CL...Is your write up in this forum? If so, what's the title? If not, where? Many Thanks!
Old Jul 5, 2004 | 07:51 AM
eric-the-red's Avatar
That's almost a quarter of a beer can, for you metrically challenged individuals
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Hiluxtrucha
Jul 22, 2015 10:00 AM
Fundy Rider
Jul 16, 2015 01:35 AM
shisha1999
Jul 13, 2015 11:09 PM
